Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
Hi i have a ride on mower its a countax rider 30 under the seat there is a pcb there is a number on it which is 44-881 on the pcb there are relys transistor and resistor and the thing i am after is the diode there was a doide on this but has blown tryedto see if could make it out the number on this but it was like dust anyone there no what sort of diode is needed please regards dean
Countax 30 rider manual
Howdie sounds like you need to go down to the Dealer And ask them Nicely hand them some cash for the Manual and then your on your Way Done
Apr 25, 2015 | Garden
Craftsman 420cc 30" riding mower wiring schematic, where can I get one?
Most of Craftsman riders has this in the owners manual.
Go to http://www.searspartsdirect.com/ and enter your model from the serial number decal. From there download the owners manual.
Jul 30, 2014 | Craftsman 30 In. 420cc* 6-Speed Riding...
Countax 2050 deck wont lift
Go to http://lawnandgarden.manualsonline.com/manuals/mfg/countax/a20_a50.html and get manual. Ensure that linkages are connected properly as per diagram.
Mar 29, 2014 | Garden
Where can I get a replacement cutting deck for a Countax K14 tractor mower?
Not sure of your geographic location but here is the contact data for Countax:
http://www.countax.co.uk/contact_us.htm Call them using the 0800 number on the linked page.
Parts link:
http://www.greenstripe.net/Parts-diagram/Diagram-405_Page-1.aspx
60 32726700 36 IBS DECK SHELL £300.11 view 60 32726601 38 IBS DECK SHELL £301.75 view 60 32726500 32766500_34 £302.82 view 60 32732500 48 DECK SHELL £265.49 view
If you not in the UK, I need to know your location please to locate other sources in your area.
Thanks for choosing FixYa,
Kelly
Aug 24, 2011 | Garden
Craftsman riding lawn tractor shuts off when coming off the brake
There is a safety switch in the seat that shuts the mower off if there is no rider. The mower stays running when the rider gets up ONLY if the brake is set. The switch under your seat is broken and cannot sense that a rider is on the seat. Therefore, the engine can only run when the brake is set. Depending on the mower, the two wires need to be connected (or disconnected) when a rider is in place. I do't know what mode your mower needs but it shouldn't take long for you to figure it out.. The safest thing is to confirm the seat switch is the issue then change the seat if replacements are available. Good luck Please rate me Mark
Jun 04, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cant find my model number on my mtd yard machine riding mower and i need a replacement part. it is a rear engine 8 hp 30'' cut
Hi, it should be under the seat. but if it is a engine part you will need the engine make and serial number
Oct 23, 2009 | Garden
MTD ride on mower, blades turn but it doesnt go forward or backwards, not sure if there is a belt missing
Sounds like the drive belt is either broken or worn out. It is under the frame and you will have to take the deck off to get to it. If you have the model number,from under the seat, go to www.precisionope.com. Look under OEM parts and you will find a part number for the belt.
Good Day.
Oct 09, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Trying to find replacement belts for a Craftsman Riding Lawnmower. 6 speed 46'' cut EZ 3 Mulching Family SKH 624U1G2RB Model #CV207 Serial # 2811705321
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=craftsman+rider+belts&_sacat=See-All-Categories
They do have some for your rider here on ebay.
You can also Go to http://www3.sears.com/ Enter your correct model number (the one under the seat; starts with 917) then continue to the diagrams list
May 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
153 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
