Question about Hydro Quip Inc HEATER ASSEMBLY FOR VERSA (AIR CONTVER) 228730600523 ()
The unit goes out on high limit tripped and needs to be reset but keeps going out on high limit tripped.
    Scholar:
  • 111 Answers
Hi Limits are a safety device, your only option is to replace bad hi limit with a new one. Do not try and repair or adjust a faulty one.
They are fairly in expensive just be sure to replace one with the correct bulb or probe length and diameter.
Bulb style here
or Probe style here.
Posted on Dec 28, 2011
Reset button on a o smith keeps tripping
After the high limit trips once, it is no longer calibrated. Replace the upper stat and limit.
Mar 21, 2017 | Water Heaters
Blower motor does not shut off after burner goes off
High temperature limit may have tripped. It should reset when cooled but may have failed and will not reset. You could also have a manual reset limit safety which needs to be reset.
Sep 16, 2014 | Heating & Cooling
Why Deep Fryers pilot goes out all sudden?
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces and electrical current that keep the pilot on and allows the main gas valve to open. Be sure that you have a good pilot flame. The pilot may need to be cleaned or adjusted. The thermopile is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Aug 22, 2014 | Kitchen Appliances - Others
The burner will not be lit and the ignition goes out
Aug 07, 2014 | Cecilware Kitchen Appliances - Others
Why does the deep fryer pilot goes out
There are several possible causes of this problem, aside from a loose or damaged wire, which is uncommon. The cause in about 95% of the cases is a thermopile that has gone bad. The thermopile is the small cylinder that is attached to the pilot assembly where part of the pilot flame can contact it. It has a cable or wire going to the gas valve, high limit switch, or both. When hot enough, it produces an electrical current that keep the pilot on and allows the main gas valve to open. Be sure that you have a good pilot flame. The pilot may need to be cleaned or adjusted. The thermopile is not hard to replace in most gas fryers and not too expensive. This often starts as an intermittent problem. The second possible cause is a defective high limit. The high limit is a small rectangular device with wires going to the gas valve and a tiny stainless tube that goes through the bottom of the kettle to a sensor bulb, like the thermostat has. These are usually self resetting, but may have a small red reset button. If present check the reset. If no reset, jump the two wires and see if the fryer will now light. If so, the high limit is defective, assuming the fryer is not over temperature. If defective, replace. Do not operate the fryer in this condition as there is no over temperature protection. The next cause is if the oil is too hot, in which case the high limit will shut off both the main burner and the pilot. The pilot cannot be relit until the fryer cools down and the high limit resets. If the oil is too hot, usually over 425F, replace the thermostat. If the high limit trips when the oil is in the normal operating range, replace the high limit. The final cause is a bad gas valve. This is not too common, but the gas valve is expensive and a bit difficult to replace. Check all of the other causes first.
Jul 14, 2014 | Vulcan EF4 Deep Fryer
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
Apr 18, 2017 | Heating & Cooling
Intertherm model# FEH-015HA It is no longer blowing heat
High limit safety device is probably tripped, it should reset automatically, also check other safety's for tripped condition, they look like small round device located in a variety locations through out the unit with two wires to each one, some have small push button resets located in the burner compartment area. If all the safety's are reset and check out OK the main control board may need replaced. One of the most common causes of high limit safety device trip is lack of air flow, Dirty filters, evaporator coils, malfunctioning blowers, closed supply air registers etc.
Note: High limit safety switches also go bad after being tripped to many times.
Nov 28, 2011 | Heating & Cooling
The pilot light is good if I turn the temp beyond 350, then the burner would go out (the natural gas would shut off at that time) Would you tell me which is the problem and where to buy...
Need more info.. but here goes. If the temperature gets too hot the unit will shut off on hi limit and will reset after it cools down some. This will cause the burner AND the pilot to go out. You need to make sure the temp isn't going over 400. The thermostat my be out of calibration causing the high limit to trip..or the high limit could be shutting the gas off prematurely. You must check the oil temperature when this is happening. It sounds like the high limit device is doing it's job and that the thermostat is letting the oil get too hot.
Tom
Jul 31, 2010 | Vulcan EF3 Deep Fryer
My fryer will not heat up consistently. If i press the reset button, it heats up. But after heating up to a certain temp it shuts down and stops heating. There is power to the unit, it seems like a problem...
It probably is a problem with the thermostat. The reset button is probably a high limit. The high limit is a safety device to turn the fryer off if the oil gets too hot. Normally they will "trip" somewhere between 375 - 450 degrees F for commercial fryers. I would suggest placing a temperature probe in the oil and see what the oil temp is when it trips. If it trips at a temp below 375, it is a bad high limit. If the thermostat is set at 350 and the temp goes over 400 then the thermostat is bad.
Feb 03, 2010 | Kitchen Appliances - Others
I have a dyno glo rmc-fa100dlx forced air heater. It will light and work for a few minutes, up to about 5, then it will stop heating and the fan will keep blowing. any ideas? thanks!
If the unit comes on and runs but then shuts down, that sounds like an indication of a high limit trip.
Most, if not all, furnaces have high limit switches that keep a constant check on the temp inside the furnace or air handler. On most systems, once this high limit switch has been made (got to hot), the limit switch breaks control voltage to the heating device (strips, gas, fuel, etc.etc..). The blower motor continues to run until the high limit has dropped in temp and reset itself.
On some models, the high limit is a manual reset, meaning you need to reset the switch yourself or shut the unit off and then back on to reset it.
Check all filters and replace as necessary. Check the coils and fan blades for dirt build-up and cleanliness. Check motor belt (if applicable). If all these fail to solve the problem, then your issue either lies within the blower motor itself not moving enough air for proper heat transfer. Or the high limit switch itself is failing.
Jan 09, 2010 | Heating & Cooling
Hydro Quip Inc HEATER ASSEMBLY FOR VERSA (AIR CONTVER)  228730600523 () Logo
426 people viewed this question
Top Hydro Quip Inc Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Hydro Quip Inc Pool and Spa Expert? Answer questions, earn points and help others
