Question about Toshiba CF19G22 19" TV
Digital or analog?
Just wondering if the Toshiba CF19G22 TV is digital or analog? Will it need a converter box for the changeover coming in 2009?
    President:
  • Toshiba Master
  • 1,779 Answers
As long as you are on cable you will not need a box.
Posted on Mar 28, 2008
We have an indoor antenna and was wondering if we need a converter box to bring in digital channels?
Hi Virginia, we went through the analog/ digital changeover
here recently and it is all fairly straight forward really. If your tv is digital then you need no converter box. If your tv is analog then you will need a cnverter box. Some tvs are dual system compliant so only need to be switched over
The difference a good quality aerial makes to digital broadcast reception is great, I currently use amplified indoor aerials and they are adequate for our two sets but a good extenal aerial would be far better.
In direct answer to your question I believe you need an amplified indooe digital aerial if you eant decent digital reception.
An old analog aerial may not do the jov ....but you can always try it before buying any new equipment
Jul 16, 2015 | Televison & Video
Does my Toshiba 65H14 TV need a digital converter box
If your TV is an older TV, everything changed when DTV (now meaning Digital TV) became the default on Friday, June 12, 2009. Older TV's (are analog, newer digital) require a converter box.
Jack
Apr 05, 2015 | Toshiba Televison & Video
How do I get my to work with an antenna
If its a standard analog tv made before the digital changeover it will no longer work directly connected to an antenna as there are no more analog tv transmissions,to use it you will have to get a digital to analog converter box to connect between the tv & antenna it will convert the incoming digital signal to analog so the tv can work again,the same goes fore vcr's they will no longer record directly from an antenna.Some cable systems still supply the cable signal in analog older tv's will still work without boxes on these systems.
Oct 05, 2014 | Televison & Video
I just received a tv from my church and it is a toshiba 27df46 27" tv. It says" please wait, thank you for your patience". I wait and nothing, Help please? Thanks.
The set is trying to auto program the available channels and it can't find any because since the change from analog to digital [FEB 2009] broadcasting requires a "converter box" to translate the digital signal back to analog. Check around and see if you can find a converter box. They were available for $20 with a coupon, maybe they still are. Try an electronics shop or dealer for that info.
Apr 16, 2010 | Toshiba 27DF46 27" TV
Is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
May 13, 2009 | Mitsubishi HS-U446 VCR
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
Determining if TV has a digital tuner
No! this TV will need a converter box!
Please rate my quick response!
thank you!
Jan 13, 2009 | Televison & Video
I have a sony trinitron wega tv model number KV-32FS120 and I was wondering if it is digital ready or do I need to get a converter box
This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products.
Jan 06, 2009 | Televison & Video
Tv
The changeover only effects those that use either rabbit ears or a rooftop antenna. It sounds like you have cable TV which will not change. No converter box should be needed if you have cable or satelite.
Dan
No real problem yet
yes,,,ur TV is a digital one...
Jan 28, 2008 | Sanyo DS25390 TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
