Question about ProMariner Advanced Onboard Chargers Model Prosport 8,12/24volts, 8 Amps,2banks
I need a wiring diagram for ProMariner XPS 5/5 2 Bank on-board marine charger to hookup two 12-volt batteries to make a 24-volt system
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Hooking up a 36 volt charger to three 12 volt batteries in series
first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
Aug 29, 2013 | Minn Kota Boating
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
Unit will charge for an hour then all of the lights on the unit blink one at a time in a rapid fashion, this unit is only 6 months old!!!
You either had a lot of exposure to moisture at some time or you did not,. If you did not then get a new unit on your guarantee.
Aug 13, 2010 | ProMariner Prosport 20 Plus Gen 2 Heavy...
No power like it is running on 12 volts need to know how to wire for 24 volts
I would first put a voltage tester on there and see if your getting 12 or 24 volts... You could have bad batteries... As far as running a 24 volt system the best thing to do is to set it up based on the owners manual... My 24v system has the position from battery (1) one going to the motor (put a fuse on that thing), the negative on battery (1) one goes to the position on battery (2) two. The negative on battery (2) two goes back to the motor.
Feb 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Nov 05, 2009 | Boating
Need owners manual for pro mariner battery charger model ss 30 (1990) yr
NEED OWNERS MANUAL & PARTS LIST FOR PRO MARINER SS30 BATTERY CHARGER
Oct 31, 2009 | ProMariner Boating
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Oct 20, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
ProMariner Advanced Onboard Chargers Model Prosport 8,12/24volts, 8 Amps,2banks Logo
1,107 people viewed this question
Top ProMariner Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a ProMariner Boating Expert? Answer questions, earn points and help others
