Question about Husqvarna Designer I
How can I get rid of birdnesting? I am using
How can I get rid of birdnesting? I am using emboidery thread on top and regular bobbin thread on the bottom
    Genius:
  • 1,116 Answers
Bobbin thread for machine embroidery is recommended. It is usually 60 weight.
Embroidery Library is about the best when it comes to Techniques and Tips for machine embroidery and they address bird nesting here - http://www.emblibrary.com/EL/elprojects/SimpleProduct_ELP.aspx?CS_ProductID=PR1239&CS_Catalog=Elprojects
Posted on May 11, 2010
Where to apply oil to shuttle on White model 2037. I thoroughly cleaned all parts of the machine, rewound bobbins, made sure presser foot was up and rethreaded machine, still getting birdnesting under
If the birdnesting is on the bottom of fabric it is the top tension. If the birdnesting is in the bobbin area I would check the bobbin tension. When adjusting the bobbin tension make sure you are turning the screw in very tiny increments.
Check to make sure the machine is threaded properly and then check again. It is often times something simple.
Jul 07, 2017 | Sewing Machines
Fixing the problem of birdnesting
Birdnesting is a common but very frustrating problem that can be resolved easily once you know where the problem originates. Remember, if the birdnesting occurs on the underside of the fabric, the problem originates with the upper thread. If it shows on the top of the fabric, the problem is the bobbin.
Very often, the machine is not threaded correctly. Remove all the thread from the machine. Check there are no loose threads or lint stuck anywhere in the machine. Oil as instructed in the manual.
Install a brand new needle! The needle should be suitable for the thread and fabric you are using. All About Needles
ALWAYS RAISE the presser foot and rethread the upper thread. Verify the path is correct.
Check that the bobbin is installed and threaded properly.
Pull the bobbin thread to the top of the fabric.
How and Why to Bring up the Bobbin Thread
Set the upper tension to the midway point.
While holding both thread tails lightly in your left hand, begin sewing slowly.
sewing machine birdnesting Google Search
Oct 27, 2016 | Sewing Machines
The thread gets caught up in bobbin area
This mess is commonly referred to as a bird's nest or 'birdnesting' and it's usually caused by incorrect top tension and that's often caused by the top thread not in the correct path. (For me, I occasionally forget to thread through the take-up lever.) A damaged needle can also cause birdnesting.
Aug 02, 2014 | Husqvarna Huskystar 207 Sewing Machine
The thread is birdnestting where the bobbin is
Birdnesting can be corrected by adjusting the bobbin tension lower. You need to check for threads stuck in the bobbin tension and clean them out. The thread should feed out of the bobbin tension with a small amount of tension. Make sure your bobbin is rotating the right direction; probably counter clockwise. Adjust the top to three and give it a try. You may need to make a small adjustment on the top tension. Your goal is to have the bottom and top tension equal just like a tug of war.
Jan 22, 2014 | Brother PE-500 Embroidery Machine
Birdnesting on singer 1021
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 15, 2012 | Kenmore 11101 Mechanical Sewing Machine
New home model 4018 birdnesting problem help
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
check to make sure the thread has not come off the thread take
up lever
Aug 05, 2012 | New Home Sewing Machines
How to thread Singer merritt#9608? Probledm with birdnesting
what size bobbin and do you have pictures to show how to thread 9608 singer machine
Mar 10, 2012 | Singer Sewing Machines
Top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Oct 30, 2007 | Brother SE-270D Computerized Sewing...
Tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Jan 16, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
301 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
