Question about Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw
How do you align the motor on an older (JET) JWTS-10 Table Saw. The manual does not go into it and I have looked inside the saw and can't find any way to align. The rear edge of the blade is out of alignment by about a 32nd of an inch. The blade is flat and I see no wobble.
Remove the drive belt, loosen the motor base bolts on the motor and put a straight edge on the outside edge motor pully rotate the motor till the straight edge lines up with the outside edge of the saw blade pully then retighten the motor base bolts and replace the drive belt.
Posted on Nov 08, 2010
How do i adjust the blade tilt
There should be 2 handles: height and tilt. Tilt is typically located perpendicular to the blade on the base of the saw.
Dec 28, 2014 | Jet Saws
Saw blade creeps down when the motor is turned on
You must have a problem with table saw alignment. Check your manual or you visit this site.
Sep 11, 2013 | Hitachi C10FL 10" Stationary Table Saw...
JET 708471 Manual
you can download the manual from this site
www2.woodcraft.com/pdf/708100.pdf
Sep 09, 2012 | Jet Saws
Reset button does not reset, broken, where can you get replacement part quick.
This link will take you to the parts number search page. Otherwise, start here and find your product, choose "Find Out more" to get a copy of your owner's manual, in which you'll find a complete parts list, with parts numbers. Then go to the first link to choose and order parts.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 27, 2011 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Saw worked fine until today. Kicks breaker withing seconds of starting. both 15 and 20 gfci's kicking within seconds.
What I would check for and follow closely, is UNPLUG tool turn blade by hand to make sure it turns freely, there could be a piece of offcut wood jamming the blade. then turn it on its back or however you can to see about cleaning with compressed air, check the cord condition for breaks if all the above checks out and sounds like you have tried different power sources you have an electrical short and troubleshooting this is involved.
Oct 03, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Table saw cuts off
Probably the overload trip is set to too low a current. Either this or it is faulty.
It is just possible that there is dust in the contacts which causes a bad contact but it is more likely to be the overload trip.
Jun 02, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Jet saw Manual for a JTAS-10/12
Jet's Manual site is here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is here though.
If this helped, please vote. Thanks!
May 25, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
My saw is wired for 220. I inherited it and
first of all if moving backwards it will get very hot.
Reverse the two 110 wires to make it run clockwise. it should run cooler as well running the correct direction
Feb 27, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Blade on saw not in line with table
The blade may be curved and need replacement check with a level and see first
Nov 09, 2009 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Blade type
blades are available for different applications. A few common blades include:Steel Blades are inexpensive and work well for cutting softwood. Steel blades dull quickly in hardwood. High-Speed Steel Blades are harder than steel blades and stay sharp longer. Carbide-Tipped Blades are more expensive than other blades, but they stay sharp much longer than steel or high-speed steel.
Aug 27, 2008 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw Logo
333 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
