Question about Whirlpool Dryers
Whirlpool electric dryer Model GEQ9858JQ1 will not stay running
Whirlpool electric dryer Model GEQ9858JQ1 will start when button presses but will not continue running when released.
    President:
  • 949 Answers
The problem you are describing is one of two components.
- #1 and most likely is the motor relay part number 3405281, it is located under the console, there are 2 relays that are identical under there. They both will have 4 wires. The one you will be looking at is the one where 2 of the wires are blue. NOT the one that has 2 of wires red. If you are comfortable with electrical circuits and understand this you can bypass the relay to test only!! Jump the blue wires and see if the motor stays on, if it does the relay is bad. Please be careful and do not jump something with the power on! Make tests and take things apart with the dryer unplugged
- #2 Motor, part number 661654, not likely but the main windings can be bad, it is a bit tricky to test this. To check you need to remove the wire harness from the motor and use an ohm meter to check from where the white wire and the blue wires were connected to the motor, you should get under 5 ohms.
Posted on May 11, 2010
Whirlpool ultimate care ii dryer will not stay on when start is pressed
if you push the start button an as soon as you let go of the start button your dry stop you need a new motor
Apr 24, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Jun 30, 2009 | Whirlpool GEW9250 Electric Dryer
Power working but won't stay on
sounds like u have a faulty start button. the switch isn't staying closed...
Feb 22, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer (electric)
did the button click when you pressed it when it worked fine, if it doesn't click now then you need a new button switch, which should be fairly cheap and fairly easy to replace yourself with care if the button should be pressed to start without normally clicking and needs to be pressed to restart each time you open the door then the start relay could be faulty, sound complicated but not the same fault hope i have been of some help, if so please rate me
Oct 04, 2007 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
