Question about Brother MFC-9440CN Laser Printer
When printing I have black marks that come up on the board of the paper. What could cause this?
As profound and helpful as James Young's comment was, i'll add that your printer probably needs the drum cleaned. Find the manual, explore the menus or look online for 'drum cleaning' and your printer model. For the 3070cw, this link will guide you: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002200/000056/faq002256_006.html?reg=us&c=us&lang=en&prod=hl3070cw_all
Posted on Sep 25, 2013
    Brigadier General:
  • 4,044 Answers
You need to have the machine cleaned.
Posted on May 11, 2010
I have a HP Photosmart D7160 and it won't print 4 X 6. It has black marks on the wrong side when it comes out, but not picture
Try flipping the paper. Probably you need to resize the image for this size, sounds like it is compressed and squnched together into those black marks. See if you can use a preview function.
Jul 31, 2016 | HP Photosmart D7160 InkJet Printer
Ricoh aficio 2075
R u using original toner? if no, replace ori. if yes, r the hot roller in the fuser hot enough? is there any gap between hot roller and pressure roller? toner smear can only be caused by non ori toner or faulty fuser unit. Faulty developer can cause sandy print out
Mar 22, 2014 | Ricoh Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Black marks on the printing
You could have a build up of ink on your rollers, and as the paper is pushed through it is leaving marks. It could also be causing your ghosting effect or double lines. By having your printer cleaned by a certified technician it should reslove your issue.
Jun 09, 2010 | Epson Stylus Photo 1290 InkJet Printer
My HP 1320 prints a thick black line down the left side of each page of a document.
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Jul 27, 2009 | Office Equipment & Supplies
Black ink marks on prints from Epson R380!
Hello:
I have been having this problem all day today and believe I resolved it. The photo paper is thicker (I'm using the Ultra Premium Photo Paper by Epson). I have an Epson 1280 photo printer. I opened the lid and moved the lever to adjust for paper thickness, and voila––no more black ink tracks down the one side. Since photo paper is thicker, this may be your problem as well. Check your manual and see if there's an adjustment for things such as printing envelopes and change the setting. Hope this works for you! I wasted about 6 sheets of paper until I thought to adjust for paper thickness. Please let me know!
Susan
York, PA
smfree@comcast.net
Mar 26, 2009 | Epson Stylus R380 InkJet Photo Printer
Black mark on right side of paper
The scanner is not working properly, not the printer part of the unit.
The LED array is not lighting causing black scanned prints.
Resolder the contacts in the LED array...probaly a cold solder joint.
Feb 17, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother MFC-9440CN Laser Printer Logo
150 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
