My washer has a full load of laundry in it, with water and stopped working completely.
  • 4 more comments
  • k_stark918 May 11, 2010
    helpful
    Make: Kenmore Heavy Duty 70 Series
    Model number: 110.92273100
    Serial number: CD0896979
    have not tried bypassing the switch, i don't know how easy that will be considering its full of water and I don't know how to do that
    oh, ok. we had tried that before we started looking for answers and the switch seems to work fine. my husband thinks it could be the knob. he pushed it in and turned it, then pulled it back out to restart the machine and it worked. when he tried the same thing again, nothing happened.
    sorry about the confusion. the washer is not working, it just happened to turn on for a few seconds when my husband turned the knob, but then (and now) nothing.
    ok, i just tried the washer again and now it will try to start, and i hear a humming noise, but nothing is happening..could it be over heated/ing?
    Top Expert:
  • Washing Mach... Master
  • 75,822 Answers
Need the make and model number of the washer, must have this to help u, front load or top load, any lights flashing or codes blinking from the control panel.
Posted on May 11, 2010
  • 3 more comments
  • yadayada
    yadayada May 11, 2010
    there are really just tow possibility's here, one is the washer timer motor has failed, the other is the lid safety cutoff switch is defective, have you tried bypassing the lid switch with a piece of wire to see if it runs?
  • yadayada
    the switch is in a slot under the lid, it is high and dry, stick something down there to depress the switch, u will feel the switch it is spring loaded
  • yadayada
    sounds like the washer cycle timer is defective, a little confused by your reply, so the machine is working right now?
  • yadayada
    it sounds like u need to replace the washer timer control. the part number is at the web link below. it comes with instructions on how to replace,.
  • yadayada
    http://www.repairclinic.com/SSPartDetail...
    Remember without being there to do hands on testing this is a educated guess based on what symptoms u have, u may have other parts that need replacing, I strongly suggest a qulaified service tech do the final diagnosis before u purchase any parts.
I have a Kenmore Laundry Center.I washed 1 load then started another wash load. The washer filled with water completed the wash cycle and did not spin. I cannot get the washer to start again by...
Be sure there is power is coming from wall outlet and be sure breaker hasn't tripped. Also if there is a loose connection where cord was installed to unit, there may be a burnt wire.
Sep 11, 2017 | Washing Machines
Completely dead and lid is locked
Try an extension cord to another powerpoint. Place the drain hose in a bucket and slowly lower it to the floor, lift it up when the bucket is full, continue till the washer is empty or no more water will come out. Turn the washer off at thew wall and unplug it, wait a few minutes and plug it back in, this may reset the machine so it starts working again.
Hope this helps
Terry
Nov 25, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hi! I have a Maytag Neptune front loading washer machine. On a few occasions I have found a small amount of water in the drum before starting my weekly laundry. Today when I went to start my laundry...
This is symptomatic of a water control valve not closing completely- its no power/fail position is closed.
Whichever it is, hot or cold, needs replacing!
Service call ;-0(
Good luck,
John C
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Drum smells like rotten eggs - perhaps the water is not draining completly - only smells if the machine has not been used in a few days and is the only spot in the house that smells - we have city water...
Run a hot wash or soak as your last cycle on wash day. If the unit is not regularly used an extra rinse is a good idea. If odor comes back there is still remaining residue. The area you need to concentrate on is always just 3 to 5 inches above the normal waterline where suds and soiled water splash up. If nothing else works this "splash area" can be cleaned by added a washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the splash area. Intermittently pausing and restarting the washer to soak works for extreme cases.
Mar 23, 2010 | Washing Machines
Fisher Paykel will not drain
I had the same problem. After cut the power off for at least 60 seconds and then back on, as the manual suggests, the problem remained. Therefore I started putting the clothes out and bailing the water out. Once the water was down about half way the pump started working. I suspect the sensor was "stuck". I cycled the washer without clothes and it worked fine. Still working after several loads of laundry. The water level sensor will probably need replacing sometime soon.
Dec 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Front loader locks, but nothing else. Please help!
ck to see if water still in tub if so remove as much as possible then remove bottom cover and clean pump..if you are washing baby clothes use mesh laundry bag for small items such as socks they tend to plug up pumps easily
Nov 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
