Question about Toshiba Satellite A105 Notebook
Multiple colored lines on start up. Fine if I use an external monitor but lost the sync and can't get that back now
    Brigadier General:
  • 4,044 Answers
Check the specifications for your monitor and make sure you have them set correctly. If they are set correctly you may need to replace the monitor.
Posted on May 11, 2010
It displays colorful lines on the monitor...cant see nothing
Test your laptop with an external monitor and find out if the external video goes bad too. If both, internal and external images go bad, you have a problem with the video card.
If external works fine and only internal goes bad, most likely it’s either bad video cable or LCD screen failure.
May 21, 2010 | Nvidia GeForce 7200 Graphic Card
Multiple lines on color running through image
if you have xp it should let you go back to a point where it was working correct. know what talking about? do that.
Aug 16, 2009 | HP w2207 Monitor
Black screen with vertical lines through it
Could be faulty graphics chip or faulty screen. If you can hook up external monitor and picture is fine then probably faulty screen. If external monitor shows same problem the faulty graphics chip. Take to repair shop and let them have a look.
Jun 10, 2009 | Compaq Presario M2000 Notebook
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
Computer problem/averatec 7100 series notebook
Your are in Hibernation mode. Hold the power button down for at least five seconds and then remove external power and then your battery. Re install your battery and attach external power and power back on. You should be alright after that.
This is a know issue with some laptop models running either Windows XP or Vista.
Hope this has helped or fixed ya.
Worldvet
May 16, 2008 | Computers & Internet
Vertical screen lines and resolution is in extra large format.
Possibly either or a hardware fault..
Does the pc have an external monitor port? Most do.. If you can get another monitor, plug it up and use the correct hot keys (keys on your keyboard) to switch between the laptop monitpr & the external, it might help diagnose the problem. Maybe select a generic driver for the external monitor.. Although the pc will probably pick it up ok. If you need further help, let me know. Rgds.
May 02, 2008 | Dell Inspiron 8200 Notebook
Display Problem for HP DV8230us laptop
hi there,
sounds like you have a driver or internal video card problem...but first have u tried changing the screen size/resolution and color depth/quality in your display settings...
Apr 09, 2008 | HP Pavilion dv8230us Notebook
Toshiba Satellite A105 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
