Question about Frigidaire ATF6000ES Front Load Washer
Wont pump the water out
Need to know how to access pump, how to remove front panel
  • 11,896 Answers
You will need to tip the machine on it's side and access bottom and rear panels. Then check the pump and drain screen and drain for clogs and loose parts.
Posted on May 11, 2010
Receive error message E20 on front loader washer.
Posted on May 13, 2010
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Posted on Jul 09, 2009
Is there a filter on this model
Of course. The filter is located in the pump behind 'front' bottom panel. Disconnect power, remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Be prepared for a lot of water, catch it in something to prevent more work. Clean the filter from any debris that prevents water from draining out properly. Front loaders hv filters, top loaders don't. Don't forget to click that you are helped!
Oct 18, 2014 | Maytag EPIC MFW9700S Front Load Washer
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
The water wont drain and the is a clicking noise coming out of the water pump motor
Something may be stuck in the pump impeller causing it to make a clicking or rattling noise. Disconnect power then remove the lower front access panel to access the pump filter and the pump impeller.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Drain the water into a bucket or shallow pan and lay a piece of towel under the pump filter prior to the removal of the filter. Turn the filter knob counterclockwise to remove and clean it. Reach in the pump to check if it is restricted or detached from the pump motor spline. Replace the pump assembly if the impeller is broken or detached.
Oct 04, 2010 | Kenmore Elite 45986 Front Load Washer
We need to replace the drain hose in our Kenmore Elite HE3t washing machine. How do I get access into the machine to replace the hose? Is it from the top or the back?
To replace the drain hose, follow these steps:
1. UNPLUG the washer and turn it around so you can access the rear panel.
2. Use a wet/dry shop vac and pull a vacuum on the drain hose. This will remove any existing residual water that remains in the drain line and pump minimizing any mess you may have to clean up later. NOTE: There is about a gallon of residual water that normally remains between the lower wash basket, drain lines and pump.
3. Remove the rear panel by loosening the screws around the perimeter of the back panel. With the screws removed,the panel should lift off. NOTE: There is a smaller access in the center of the back panel that can also be removed. Removing the entire back allows for better access though. Trying to work through the center access can be a cut hazard due to the sharp edges on the metal.
4. Move around the the front of the washer and remove the lower toe panel under the door. You may have to prop up the two front feet of the washer to access the screws under the bottom front edge. With the screws removed, the panel will drop down, then lift off.
Additionally removing the front toe panel will give you full access to the drain pump from the FRONT and the REAR. The pump sits closer to the front of the washer where you can easily access the hose clamps. The drain hose inserts from the rear, however.
Since you have the washer apart, now would be a good time to check the drain pump clean out trap to ensure there is no debris build up that can restrict drainage. The following link explains the recommended procedures to check the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you have any questions about any of this advice, please post back and let me know. I hope you find this information helpful.
Feb 08, 2010 | Washing Machines
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Something is stuck in our LG front loader washing machine so the water wont empty in the spin cycle
There should be two screws under the front lower panel. Remove the two screws and remove the lower panel. You should be able to access the pump from here.
Inscrew the cover on the front of the pump and clean.
Dec 31, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I need to replace the pump on my Admiral AAV70000AWW washing machine but need a repair guide manual or instructions
Electrically Isolate the machine
To access the pump the front panel needs to be removed, first the machine top needs to be opened,
at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the internal screws on the front panel and remove the front by lifting off it the bottom brackets.
Ensure the machine is empty of water, to do this lower the waste drain pipe to floor level and clooect any water in a suitable container.
Tilt the machine back 45 degrees and remove the drive belt and bolts for the pump, remove the hoses from the pump, refit in reverse order.
Jun 08, 2009 | Maytag Admiral AAV7000A
Frigidair front load washer won't drain during spin cycle
The main reason these units wont drain is because the drain pump is plugged. Remove the front access panel at the bottom the pump is located on the right hand side at the front. Get rid of water in unit with a shop vac, disconnect wires from pump remove hoses clean out pump and rubber hose to the tub reassemble and try. good luck
Dec 19, 2008 | Frigidaire Washing Machines
LG front load washer has blocked drain line which is located in
take top off remove three srcews in back ..remove 4 screws hold control console ,,dont remove connection just flip console on top of drum,,make sure unit is unpluged..your looking at 4 screws across to panel remove them open door remove spring wire clip around the out sid bellows where almost there..now careful down in the filter acess panel remove the frist screw the filter cover comes off after the cover is out remove the pump filter housing screw..and last remove thebottom panel screw,,remov panel,,pump on left is drain pump..pump on right is recrulation pump
Dec 13, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water wont drain /wont spin out
  • assuming it is a top loader
  • it sounds like something is stuck in the water pump.
  •  if the water does not drain then it will never spin.
  •  take off the front panel (with a butter knife, push in the two metal clips in the front seam between the top panel and the front panel. this will release the front panel from the machine.
  • the water pump is located on the right side in the front.
  • before removing the hoses attached to the water pump get as much water out of the machine as possible so it does not spill on the floor.
  •  then take off the hoses and check inside the pump thoroughly; even a string might cause the pump to get stuck.
  • let me know if you need more help
Mike
Jul 02, 2008 | GE Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
270 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
