Question about Casio FR-2650Plus Calculator
How do i take out the ink thingy
How do i take out the ink thing?
You will need: 1 Replacement ink roll - Porelon PR42 Ink Roll (This roll will replace the black and red ink all on one roll) Available at OfficeMax or other supply stores.
You must first remove the clear plastic cover on top of the calculator (where the tape comes out). Remove the old ink roll. You will see on the roll where it says "pull up". It will pop out easily. Replace it with the new ink roll, it will just snap in place. Replace the clear plastic cover. It should now be ready to go!
Posted on Nov 17, 2008
  • 374 Answers
It should just pop straight out towards the top. There's a little tab that you can grab and pull up on that. :)
Posted on Mar 30, 2008
MY DAISY DONT PUMP, WHAT SHOULD I DO?
It's the little cone shaped white plastic thingy and the O rings in the pressure reservoir. When you take it apart, it's the valve thingy connected to the end of the trigger thingy that;s inside the large threaded plug thingy. It's held in by a tiny C ring. Daisy USED to sell a specific repair kit that included those specific parts for that specific problem, but don't ask me if I know if they still do. Yeah, I have a 922 sitting behind the door in my den. It's the original metal receiver white diamond gun. I loved that thing growing up and I still shoulder it now and then and remember the good times we had back in the late 70's-early 80's. I've had to rebuild that exact same thing twice before when Daisy sold the repair kit for $4. Hector, good luck on your rifle, sir! I hope you can locate those parts you need!
On a second thought, if you can't locate the kit, try replacing the O rings by themselves. That might work. Those rot with age. Take the valve off, the large threaded plug with the valve thingy on the trigger thingy, and see what size it looks like and just give those a try.
Oct 17, 2016 | The Optics
My ink cartridges are full but when I print something it does not print blue or green. What can I do?
Assuming you've recently changed your ink cartridges the first thing you can try is seeing if you've placed the cartridges properly (did you remove all the plastic covering the cartridge so the ink can flow into the printer?)
If you haven't actually changed your cartridges in a while the printer might be registering the wrong ink levels. This will result in your cartridges not being as full as you think.
Another thing you could try is checking the printer head for anything that's keeping the ink from flowing. By printer head I mean the thingy that houses your ink cartridges. Perhaps there's some old dried up ink blocking the way?
Mar 12, 2015 | Office Equipment & Supplies
Waste Ink Full....how do I empty it myself?
http://www.druckerchannel.de/device_info.php?modell_ID=874&t=canon_pixma_ip3000
Jul 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
I am unable to change ink because the ink thingy won't stop in the space so I can get at the cartridges. What am I doing wrong?
Hold down the button with the drop of ink for a second and it should move to position. Some epsons have an icon on the lower right and if you click it or right click it you get a menu with replace cartridge as an option. On others you can go to control panel-printers, right click the printer, choose properties and look for a tab which says utilities.
Jul 07, 2009 | Epson Office Equipment & Supplies
I have installed new ink cartridge but printer says it is empty
make sure you pull out the orange tab thingy on the cartridge before installing it.
Mar 30, 2009 | Brother MultiFunction Center MFC-440CN...
I have forgotten how to change ink cartridge
There is a door on the front of the printer on the right corner. There is a little tab thingy on the side of the printer that you use to pull the door open. This you can do from the front, you don't need to move the printer around to get access from the side.
Pull the door down and tada, there are the ink cartridges. What a pain in the ****, took me a good 1/2 hour to find the information on the internet.
Hope this helps everyone.
Tracey
Nov 27, 2008 | Office Equipment & Supplies
Mechanism, belt came off.
Turn your machine upside down and give it a shake. Most likely, a small spring will fell out. The same thing happened to us and sure enough, it was the spring. This spring will give the tension you need to hold the belt on the plastic piece.
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
THE GREEN AND RED LIGHT KEEPS FLASHING ON MY EPSON C48
The C48 firmware counts the number f dribbles sent to a waste ink area somewhere in the printer. The printer dribbles every time it’s powered up and when the heads are cleaned. When the counter reaches 8300 the printer stops working.
A utility at http://www.ssclg.com/epsone.shtml will reset the ink counter to zero. Cycle the printer power that’s it! easy peasy. Take care though.. the ink thingy might overflow onto the carpet one day…..
NB. I don’t think that this utility runs under Vista.
Mar 01, 2008 | Epson Stylus C48 InkJet Printer
Possessed epson stylus printer #cx4600
i would suggest this http://www.supermediastore.com/cleaning-cartridge.html or a similar product from a different supplier..
Happy New Year
John
Dec 05, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Casio FR-2650Plus Calculator Logo
734 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
