Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
The dishwasher is washing with cold water & not drying although a 70 degree wash is selected
  • AEG Master
  • 43,501 Answers
Check your heating element..
Dishwasherthe dishwasher is washing with cold water & - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on May 12, 2010
Bosch dishwasher actual runtime versus indicated runtime.
The usual discrepancies with run times is due to water heating time.
For example, your dishwasher may be estimating run time + time to heat the water from cold.
If your dishwasher is connected to hot water instead of cold, it will skip the majority of the heat cycle and adjust the time accordingly.
On the other hand for other people, their dishwasher brands may say "50 minute wash" but this does not take into account heating time, so wash can be anything up to around 70-80 minutes.
Jun 01, 2013 | Dishwashers
I just rehooked up my washer and I only have cold water going to it. It will go for a while and then reads F-20. What do I do?
he F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Newer washers sense and control the incoming water temperature. If you select cold wash and cold rinse you may think that it will not ask for hot water so you don't need it hooked up but you can't do that on this washer.
Even on a cold wash the temperature sensor will read the temperature of the incoming water. If your cold water is 60 degrees then the control will sense this and it may cycle the hot water on to bring the temperature up to 70 degrees.
This temperature monitoring is something all the newer washers do. Both water valves must be hooked up to water.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F20
The F20 error is a no water detected entering machine error and yes it is related to the hot water not being hooked up.
Jan 11, 2011 | Whirlpool WFW9400S
No hot water on wash cycle
Water coming into the dishwasher should be 125 degrees if not you will have cold/warm water. This will case poor wash/dry and longer wash times. If you have correct water temp. change out your control. Your heating relay is bad. part#266746
Please rate me a 4 if I was helpful.
Have a great day!
Dec 10, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
We see white all over the spoons and the bowls and not sparkilig white.
Make sure the water is 120 degrees at start up and also that the jet dry dispenser has jet dry. This aids in the clean rinse and spotting on dishes during wash, but most importaant is the water temp. Must be 120 at start up or you get an almost totally cold water wash.
May 31, 2010 | Kenmore Dishwashers
My dishwasher is leaving scale on glass, silverware etc. Had problem once before but went away. Is there a filter or..
No, no filter. Make sure the water at start up is 120 degrees or you will be washing with cold water most of the cycle. Make sure the liquid jet dry is not empty but most of all make sure of water temp. Cold water or water below 120 will leave film and scale and also take too long to dry.
Mar 12, 2010 | KitchenAid Dishwashers
FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Mar 30, 2009 | Fisher Paykel EcoSmart GWL15
LG LDF6810ST Stainless Built In Dishwasher
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
470 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
