Question about T-Mobile Sidekick ID Cellular Phone
Sidekick iD screen white
My sidekick iD screen is completely white, however the lights and sounds work and i could make calls. anything i could do for it before getting it fixed?
  • 18 more comments
  • Anonymous Apr 10, 2008
    I have the same problem with my id and i know the flex cable is the issue. I am waiting to try the solution because i do not have a T6 torx driver. It does seem like this would work though because i have taken the screen off the phone itself and messed with the flex cable but it only temporary fixed it.
  • Troy23 May 01, 2008
    my sidekick id screen is white everything works but not the screen
  • gods warrier May 03, 2008
    screen is white and i dont no any codes
  • niblets615 Jun 18, 2008
    sidekick id screen come but is very light hard to read what on it .what can i do
  • Anonymous Aug 17, 2008
    CLEANING
  • Anonymous Oct 09, 2008
    everythign works just that the screen is white
  • Nana125 Oct 31, 2008
    i have the same problem but it works just fine...sometimes i can see a little bit...but its blank
  • Anonymous Nov 21, 2008
    i have the same problem.... do this and it will work
    http://www.repairmysidekick.org/Fix-Side...
    yes i have the same problem screen all whit sounds and everything else works.....
  • Anonymous Nov 23, 2008
    screen is white. everything works except screen. taking the battery out and putting it back in seemed to work for a while but it doesnt work anymore
  • ch3ls3a813 Nov 27, 2008
    my sidekick ID has a white screen it all the sounds n stuff works but i cant see anything on the screen.
  • TiZz23 Dec 07, 2008
    My Sidekick ID screen is white but i can still see the stuff on the screen but not clearly
  • Anonymous Dec 25, 2008
    WHITE
  • Anonymous Dec 27, 2008
    my sidekick id screen is white but there is what seems to be an ink blob covering the screen so i cant see much
  • grimcustoms Jan 12, 2009
    i got a damn white screen
  • Anonymous Jan 17, 2009
    i was using my sidekick Id and it droped but not hard and like my screen went white and i took out the batterer and now i cant tell if its on or if its off help
  • cams23 Jan 23, 2009
    My sidekick ID is sometimes working and when it does the screen is upside down when it is flipped upwards. The screen turns completely white from time to time. Please help. People say its water damage but I am almost 99 percent sure it isnt
    Thanks
  • pretty-des May 06, 2009
    My problem with my sidekick id is that my screen is blank i cant see anything and i wanna fix it.
  • Anonymous May 24, 2009
    I have the same problem, what did you do to fix it?
    My sidekick ID screen is white can i fix it if so how much would it cost to get it fixed?
Take out the battery blow it 15 times then blow the back of the phone 15 times your hardest then out the battery back into place and then the loading screen would show thats what happen to me i hope it works good luck
Posted on Jan 24, 2009
    President:
  • 625 Answers
If you sidekick ID screen is white, you may be able to fix it. The flex cable connection cable on the lcd screen itself can come loose. Chance are if you tighten it, the screen will work again. I have had success with sidekick II and sidekick 3 with this same problem.
The following instruction for a sidekick 3 but it is the same for a sidekick ID. Just reseat your lcd instead of installing a new one.
Sidekick 3 LCD Screen Only Replacement
Posted on Mar 30, 2008
  • 1 more comment
  • Terry Fritsch
    Terry Fritsch Apr 10, 2008
    Instead of a T6 torx, you can use a small flat head screw driver that jams into two of the slots of the screws. It works in pinch!!
  • Terry Fritsch
    Terry Fritsch Dec 16, 2008
    I mean unplug the cable to the lcd and plug it back in
  • Terry Fritsch
    Terry Fritsch Dec 26, 2008
    Here is an better guide for reseating the lcd cable to repair the white screen on a sidekick.
    My Sidekick has a white screen
    Hope that helps you all out.
When you say reseat what do you mean
Posted on Nov 10, 2008
Same here th screen is white but evrything works?
Posted on Nov 12, 2008
My screen is white it wont show anything but i can
I believe your screen may have a bad connection to the handset, try flipping it many many times using more pressure then normal
Oct 12, 2009 | T-Mobile Sidekick ID Cellular Phone
MY SCREEN ISNT LIGHTING UP
ebaby-
If the screen is glowing white, then you can try reseating the flex cable at the lcd.
Here is a guide on how to do that.
fix white screen on sidekick ID
Try that, if it doesn't work then a new lcd assy will fix
Dec 13, 2008 | T-Mobile Sidekick ID Cellular Phone
My screen turns faint...
maybe try going to settings and click on battery and display and fix the light setting u have set on there if thats not helping then try calliing t-mobile
Jul 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick id screen
Seems you need a new Lcd assembly i can provide you with one very cheaply please contact me at sk3repair@yahoo.com I can sen you a new Lcd or u can send me the phone for repair
Jul 21, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick ID screen
Call t-mobile if the phone is stillunder warranty
If not then follow this procedure.
Fix Sidekick White LCD Screen
It will usually fix the problem
Jul 05, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick screen blank
Call T-mobile if the phone is still under warranty. They may fix it for you.
If not follow this procedure, it usually works.
Help
Mar 27, 2008 | T-Mobile Sidekick ID Cellular Phone
My sidekick id
Is the screen white or black?
If it is white you may be able to fix it, black maybe not.
Mar 23, 2008 | T-Mobile Sidekick ID Cellular Phone
T-Mobile Sidekick ID Cellular Phone Logo
2,188 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
