Ritetemp propane log
I have Pro-Com propane decorative stove model rt300tq. When I press the thermostat control valve down in the pilot position, propane comes out of the pilot tube in "Blow Torch" volume and then goes out? What is wrong?
  • Zanepup Dec 11, 2008
    I have a Rite Temp propane fireplace also, I bought it Dec 8 2008,
    it lights up, runs for about 3 min and then it goes out!
  • 109 Answers
Your pilot assy is clogged, disassemble the pilot assy completely and inspect the orifice. there should be a tiny pinhole in the end of the orifice, clean well with small wire brush and reassemble, don't forget to clean the thermocouple while you have the assy out.
Posted on Mar 30, 2008
Propane smell with pilot on and burner ring/thermostat off. Pilot off no smell. Pilot light is good, burner ring burns cleanly. Logs correctly placed. No line leaks. Failed shutoff valve how to fix?
This is a major hazard, you need to take pictures of the whole thing and then disassemble the whole thing and use ptfe sealant and reassemble the whole thing. Unless you want to get a sniffer to locate the issue, If could also be the pilot pressure is too high and the pilot is not burning all the gas. You may want to call a pro due to explosion risk.
Jan 10, 2016 | Heating & Cooling
My pilot stays on on my propane furnace but will not light up
The Little Giant units use a Unitrol gas valve very similar to a water heater in the home. #1,urn the Unitrol gas valve to the "PILOT" position to ignite the pilot. Depress the plunger and hold it down then push the spark igniter button until you can see the pilot flame ignite.
You have a lit pilot so this is not a problem for you.
The pilot light stays on continuously by design.
Once the pilot flame is established, you then turn the on/off/pilot valve to the "ON" position and set the thermostat to the desired temperature range., it should then fire its main burner until the desired temperature is reached. Once the temperature is reached, the main burner will shut off and the heater will go into a standby mode with the pilot flame still burning.
If you have turned the pilot valve to on and set the temperature high, it should come on, if not a new gas valve is required, they can be very difficult to replace due to rust.and most cases require a new unit,
Mar 19, 2015 | Unitrol Propane Heater Valve - Little...
I have a Waterford gas log stove. The pilot light is on and working. The stove won't turn on either when it's called on by the thermostat or when I switch the stove to "on".
You have a bad thermostat is what sounds like when you turn it on yourself there is a electric valve that opens to make work and it is not getting the signal or you have something in the line feeding it.
Jan 29, 2013 | Heating & Cooling
The pilot light won'jt light in my warm morning propane gas stove
If you dont have gas coming thru while holding down the button, you have one of the following; no gas, main valve off, or a bad gas valve.
Jul 21, 2017 | Heating & Cooling
Our LP Buck Stove will suddenly not lite. The pilot is lit. To start the stove, we just push the ON button and the fire lights, it stopped lighting without warning yesterday. Any ideas what is wrong? I...
If I understand it correctly, the pilot light will light and burn, but when you turn the Control Knob to the ON position either the burner won't light? My question is, doe the pilot stay lit or does it go out, when you do this.Also, is this a Vented or Vent-free Gas log Stove?
If it's vent-free, the Oxygen Depletion Sensor (ODS) which is part of the Pilot needs cleaning. As, it may be clogged with dust, lint & pet hair and it's sensing that there is not enough oxygen for safe combustion. The other issue tis relative to the pilot assembly, is whether this unit has a millivolt control valve and the Thermopile has failed. The Thermopile controls the opening and closing of the gas valve when you turn the Control Knob or ON/OFF switch to the ON position.
If it's a Vented unit, the same thing applies to the Thermopile.
It would also be wise to check the amount of gas you have in your tank. It may be to low to sustain combustion of the burner(s), but has just enough to keep the pilot burning.
Hope this helps you to Troubleshoot the problem. If it does please leave me a positive approval.
Mar 26, 2011 | Heating & Cooling
PIlot light on will on kick on from thermostat or manual switch on stove.
I think what you're saying is The Pilot Light is on, but the stove will not come on using the Thermostat or the Manual Switch on the stove.
If that is the case, first check the Control Knob of the stove's Control Valve. Is it in the ON position or the Pilot position. If it's in the Pilot position, turn it to ON. If that's not the case, check the wiring from the the thermostat where it connects to the Control Valve terminals to make sure it isn't loose. One wire should go top the TP terminal and the other to the TPH terminal. Also, check the position of the Manual ON/OFF Switch, it should be in the Remote or Neutral (middle) Middle Position. If some cases, it has to be in the OFF position for the Thermostat to work.
If all of the above checks out OK, check the pilot flame to make sure the flame is touching the Thermopile. If the flame is curling up and away from the Thermopile, the pilot needs cleaning.
And last but, not least, if all else fails to solve the problem, the Thermopile needs to be replaced. As, it's not generating enough millivolts of electricity to open the control valve and allow gas to the burner(s).
Hope this helps you troubleshoot the problem and make any necessary repairs.
Please be kind enough to rate my response to you. Thanks!
Mar 25, 2011 | Heating & Cooling
After filling our Fleetwood 2005 Discovery RV with propane, we could not get any of the propane appliances to light. We turned them all on, and nothing happened. We have tried to get the air out of the...
Robert, the best way and safest way to purge air out of a gas line is to use an appliance that you manually have to light the Pilot on. Turn the Control Valve to the PILOT position, push in and hold it. Keep in mind, if you don't feel strong pressure pushing back at you (more than spring pressure) the Control Knob is not exactly in the PILOT position. If that's the case, turn the knob a hair one way or the other until you find it. Hold the Control Knob in until you smell gas. Then wait 5 minutes before trying to light it. It may take up to 15 minutes or more to purge air out of the lines, depending on how long they are.
In regards to Emergency Shutoff Switch. The way to test if it's On or OFF ... is while you're holding in the Control Knob in the Pilot position as stated above, hold the flame of butane match (Like you light a grill with) in front of the pilot. If the flame flutters or moves significantly, there's air in the line, so the Emergency Shutoff Valve is ON. Conversely, if you get no flutter or significant flame movement, the the valve is OFF. Also be sure that the LP tank valve is turned ON completely .
Hope this helps you sole the problem.
Mar 09, 2011 | Heating & Cooling
My remote control (SKY-3001) doesn't seem to communicate with the propane stove.
Sounds like either the batteries are weak or it's lost it's security code. Also, be sure the slide switch on the front of the receiver (the Black Box) is in the Remote position. If after changing ALL the batteries (4-AA in the receiver and 2-AAA in the hand held remote) and they're all positioned properly and it still doesn't work, check the LCD screen to see if the child lock or lock out has been activated. If so, deactivate by pressing the Mode button and the Up button at the same time and hold for 2 seconds. The Lockout icon should disappear.
And finally, if all else fails you'll need to reset the security code. There are 1,048,576 unique security codes, but you'll need only one.
When matching security codes, be sure the slide switch is placed in the REMOTE position; the code will not "LEARN" if the slide switch is in the ON or OFF position. Program the remote receiver to learn a new security code by using a very small scree driver to push in the LEARN button (on the top of the fron of the receiver to the left over the ON position) while at the same time pressing the MODE button on the hand held transmitter. A change in the beeping pattern, at the receiver, indicates the transmitters code has been programmed into the receiver.
The microprocessor that controls the security code matching procedures controlled by a timing function. If you are unsuccessful inmatching the securiy code on the first attempt, wait 1-2 minutes before trying again - this delay allows the microprocessor to reset its timer circuitry and try up to two or three more times
If all of the above solutions fails to solve your problem contact SkyTech Technical Service at 888-672-8929, Monday - Friday.
In the meantime, if you want or need to use your gas log stove for supplemental heating, move the slide switch to the ON position and the burner(s) will light. That's assuming that the gas control valve on the gas log stove is turned to the PILOT position. To turn it off, move the slide switch to the OFF Position and the burners will go out and the pilot will remain burning.
Good luck. Please let me know how it worked out for you.
Feb 06, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Hi. i have a vermont castings radiance stove, RDV40. the pilot light went out and won't reignite. yes, the gas is on. i've followed the manual -- turning the control knob to pilot and pressing the ignition...
check to make sure your pilot orfice is not clogged it will be located at the end of the small tube coming from your gas control valve if its not then while you are trying to light the pilot tap the side of the gas valve (sometims somewhat hard) if it then lights you know you have a bad gas valve
Aug 25, 2010 | Heating & Cooling
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
Heating & Cooling Logo
926 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
