Question about Kitchen Ranges
Hotpoint oven overheating
I have a Hotpoint range that had been taking a long time cycle off during a preheat even though the oven seemed to attain the temperature that I was setting easily. I presumed that the thermostat or temp probe was failing and that I would need to see if I could replace it.
Recently the oven overheats regardless of the temperature setting with the elements constantly on and turning the dial down to see where it would cycle off would make one think that it hadn't even begun to warm.
There is (what appears to be) a temp probe located inside upper center rear area of the oven near the broil element that looks pretty crispy - including the wire that goes out of it and exits through a small hole in the rear wall and now appears to be lacking any thermal insulation - presuming that there was some orginally.
Is this a replaceable part on these models and where would one purchase the part if it is available? Should I be looking for an additional problem?
Hotpoint range
Model: RB525 S1AD
Serial: LL116415H
Thank you,
Jake
  • jroztocil Mar 30, 2008
    Thanks for the info and the link... clicked and purchased.
  • 83 Answers
Yes this is repairable, the probe in oven called a thermostat,that wire that goes out the back small hole goes up to the oven temp. knob ie thermostat. part # .WB20K10004 you can find it at
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=824183&PPStack=1 about $60.00 good luck
Posted on Mar 29, 2008
Oven preheat times
It gas not electric. There is NO hidden element. It a bad sensor.
Mar 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
We have an electric hotpoint range and ran the oven cleaning cycle today and now the door seems to still be locked even though it should have had enough time to cool down.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2010 | Hotpoint Kitchen Ranges
I have a hotpoint gas range with electronic controls. When i put the oven on preheat the igniter glows but the gas does not come on. this problem happens 50% of time.
You may have a low voltage problem, especially if it occurs at about the same time every day, but more likely you will need to replace the igniter. Even though you see it glowing, often times as they age they start to draw fewer amps, resulting in your exact symptoms.
Sep 04, 2008 | Kitchen Ranges
Hotpoint oven
From MNTECH, "If your oven would light sometimes, but usually not, or take a very long time to ignite, then replace the oven igniter. Even though it probably is glowing, it needs to draw a specific minimum electrical current (in amps) for the gas safety valve to open and release the gas. Also low voltage can affect how many amps the igniter draws, so that may be a factor, but not as often."
I live in Japan. I got a brand new range in june and it has had this problem for four month. The igniter glows but the gas never (or rarely) releases. Often it would preheat but not maintain the temp while baking. **augh** After reading MNTECH's solution I got a transformer and plugged my range into it to change the voltage (100 to 110) and I haven't had a problem since. THANK YOU MNTECH FOR POSTING THIS SOLUTION
Aug 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Oven takes a long time to preheat
Before we go into diagnosis mode, call the customer service # in the owners manual and complain about the problem.  They usually will make a concession when it is this close to the warranty period.  Let me know what you find out.
Oct 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Bake part of kenmore not working seems to take to long
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Comment by fridgetech, posted on Oct 20, 2007
Should be able to remove the bottom drawer and unplug the ignitor from below.  Or you can cut the wires on the old ignitor and splice the new one in using ceramic
Oct 20, 2007 | Hotpoint RGB745 Gas Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
1,370 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
