Question about Philips 17MD255V Combo
Screen won't come on
I use my magnavox 17md255v as a pc monitor. I went to switch from pc to tv, and my screen went blank. I turned it off and back on, and I only got a quick glimpse of the screen and then it went blank again. I checked all the cables and connections and they were all good. I disconnected the magnavox from my pc connections and tried playing by itself in a different room as a regular television and the screen wouldn't turn on - nothing. I currently have a back up monitor for my PC until I figure out what's wrong with the magnavox. Could it be just a simple bulb inside?
  • Philips Master
  • 8,457 Answers
When u try it as a tv no picture,but does it have sound?Than ur LCD inverter board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter boad for the replacement.It a long board in shape.
Posted on May 11, 2010
Im having the same problem. It used to work but the sound would come from my Toshiba laptop. For some reason, now the AVOL 32in Multisystem TV will not recognize HDMI input. I used to use it for my xbox 360 as well and now the TV does not recognize that either. Is it possibly a switchboard or something similar wrong with the TV?
Posted on Jul 09, 2011
I can not get the avol tv to change modes for dvd or as a montor for my laptop
Posted on Sep 06, 2010
What connection do I need to use Magnavox 17" Model 17MD255V/17]TV/DVD as a monitor on a computer? Error message says "No PC Signal" Monitor cord is on. Power cord is on. What's missing? thx
You need to let the Magnavox know what signal it should be displaying. Look for a "Source" button on the remote or menu and choose PC or whichever slot you are hooked up, say HDMI.
Mar 29, 2017 | Power Computers & Internet
Where is cable hook up located on back of tv
silver threaded cylinder, about one quarter inch around.....this is called an "f" connector
Jun 07, 2014 | Magnavox 17md255v/17
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
I have a Magnavox 15' HDTV monitor and it won't turn on, when I push the on switch on it turns green and a split second later it turns yellow. whats wrong?
This is typical when there is no communication with video card. Test on another PC. Re-seat video card on PC. Use VGA cable instead of HDMI or DVI. Make sure monitor is correct mode. Again VGA, DVI, or HDMI, depending on cable used.
Aug 27, 2012 | Philips Magnavox Computers & Internet
The screen stays blank when I switch the laptop on. Is it something to do with the snooze facility ?
Did you have it plugged into an external monitor or TV? If so you need to toggle it back to using the notebook's monitor. If not, you may have a bad display or a backlight that went out.
Jul 10, 2011 | ASUS Computers & Internet
I have a Philips Magnavox 17MD255/17 LCD TV. I can not find the actual ac/dc power adapter, they are no longer available. Which one would I be able to use?
http://cgi.ebay.com/NEW-AC-Adapter-Philips-Magnavox-17MD255-17-LCD-TV-/270636758732
try this they are all 12v 5a so you can do it on your own
Sep 22, 2010 | Philips 17MD255V Combo
Hi, I have a Magnavox 17MD255V/17 combo dvd-tv. Everything works fine except that the AC adaptor has a high-pitched whistle that continues while the tv is on. I tried unplugging from the the tv itself and...
TAKE THE AC ADAPTER APART. LOOK AT WHERE THE MANUFACTURER PUT HIS GLUE AND REDO IT CLEAR NIAL POLISH WORKS BETTER IT FLOWS UNDER THE PARTS BETTER. YOU CAN PLUG IT ALL IN WHEN ITS APART BUT MAKE SURE NOTHING CAN SHORT OUT. THIS WAY YOU CAN PINPOINT WHERE THE NOISE IS COMING FROM. OTHERWISE GLUE THE TRANSFORMER AND ANY SMALL FERRITE BEADS THESE SWITCHED MODE POWER SUPPLIES OPERATE AT HIGH FREQUENCIES AND LOOS PARTS CAN VIBRATE CAUSING THIS NOISE.
Dec 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Aug 24, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
Blank tv screen when turned on
the problem is in your tuner section or video if section check for its proper voltage. if you are not tech. person get the help of tech person it is not a major problem.
Oct 01, 2007 | Philips Magnavox 20MT4405 20" TV
MAGNAVOX BIG SCREEN TV
Hi, I am having the same exact issue with mine. Although, it is only about 2 yrs old. We are still trying to find out what is wrong with it.
Aug 01, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 17MD255V Combo Logo
1,231 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
