Question about Maxtor Shared Storage II (S01R320) Hard Drive
I have a maxtor shared storage II NAS. Appears that the device itself failed and possibly one of the disks. It was set up as a RAID1. I've been trying to recover my client's data. When I mount the drive under Ubuntu, I'm seeing data - but none of my client's data. Currently, I'm rebuilding the array. (I duplicated the existing hard drives onto new disks). For what I've been able to detect, disk 0 had issues. Disk 1 was fine. I had similar results as shown on http://kuparinen.org/martti/comp/ubuntu/en/raid.html in the "sudo mdadm --query --detail /dev/md0" section, except that the bottom lines were flipped.
  • 4,889 Answers
You should try a data recovery software that can read the disk before the system boots. That is your best chance to recover the data. I recommend data rescue PC.You can download the free trial to see if it can read the data. Burn the bootable ISO to a CD and boot from it. Scan the partition in question and see if it can find your client's data. If it can then you will have to purchase the software to be able to recover the data.
http://www.prosofteng.com/products/data_rescue_pc.php
Posted on May 11, 2010
Invisible network hard disk
well, if you can Ping it, then the firewall is not likely going to be blocking it. Regardless, which product do you have ? The Silver Stone 2-drive NAS ? If yes, you should be using the FNS Assistant (FNSA)
The Freecom Network Storage Assistant helps you to locate your Freecom SilverStore 2-Drive NAS in your network. It can also be used to:
- quickly open the SilverStore 2-Drive NAS configuration website.
- configure the basic settings.
- mount shared network folders.
a) Start the FNS Assistant and select the device from the device list.
b) Go to "Web interface of your Freecom Network Storage device" for initial configuration
hope that helps.
Mar 31, 2014 | SMC Barricade g SMC2804WBRP-G Wireless...
Hi. I configured my Maxtor Shared Storage II with my home PC. Now the PC is dead. I tried to connect the other my PC (with Windows 7 as operating system) to Maxtor Shared Storage II, but the PC cannot see...
try and assign the drive a drive letter by right clicking on my computer and choose manage.
go to disk management
look for the maxtor hard drive.
if you see it listed there below you should be able to right click on it and assign a drive letter.
if you dont see it then it doesn't detect the hard drive. please check your hard drive connections and try again.
Mar 06, 2011 | Maxtor Shared Storage II (S01R320) Hard...
What is nas
network attached storage server using bsd.used for backup
www.nas.org
Feb 05, 2011 | Microsoft Windows XP Professional for PC
Trying to get my maxtor II to work with windows 07 software but it wont read the usb connection? After i have installed the software for maxtor.
Check Control Panel, System, Device Manager and make sure windows see's the connection. If you see a yellow triangle, that means the drivers are not correct. If you don't see it at all, that is a problem. Give Maxtor a call. You may need to update your motherboard bios, chipset drivers. At worst, you might have a problem with the motherboard or maxtor II device.
Feb 26, 2010 | Maxtor Shared Storage II N01R010 1 TB USB...
Stored static ip address in nas server and cant
I have a similar problem. There is a reset pinhole switch just beneath where the Ethernet port is that if you push it is supposed to reset the drives name and switch it to DHCP. You can see this in the manual. Unfortunately, this hasn't worked for me and I'm working through another solution to see if I can find the IP it is attached to.
Apr 21, 2009 | Maxtor Shared Storage II 2TB Network...
Different RAID configuration?
The first point to note is that this unit does not support more than 1.6TB total disk. (4 x 400GB drives) This is stated in the manual which is on the CD that came with the unit. You cannot configure a mix of RAID1 and Linear (JBOD) drives, so you plan will not work.
Jun 18, 2008 | Computers & Internet
Unable to see Shared Storage Drive II on EasyManage via Wireless
Just got a Maxtor Share II drive and absolutely love it. Setting it up was a pain especially when the drive didn't remember the Administrators password.
Here's what I think the problem may be
1-Your router is not assigning an IP address to the drive
2-Make sure your router is configured to DHCP IP configuration not Static.
3-Before trying to use the drive make sure to install the Software/Drivers first.
Other suggestions
This may or may not apply to you. I got my Maxtor drive on 4-07-08 and from previous experiences with other computer products, ie, windows software, printer drivers, etc. The manufacturer in order to rush things out the cd software that comes with the product is not the final version and most likely the software already has an update on the manufacturer’s web site so it’s always good to check before committing to what you get on the CD. So sure enough the BIOS for my Maxtor Share II 500Gig hard drive was already old. I downloaded the new version upgraded the BIOS and my drive is working great. I hope this suggestions help. Enjoy your drive. Alfredo.
Apr 09, 2008 | Maxtor Shared Storage II (S01R320) Hard...
Cant Share Printer on MAC
What have you tried? Can the Mac see the printer at all? Is the Share Storage attached to the Mac or the Windows machine?
Aug 02, 2007 | Maxtor Shared Storage II (S01R320) Hard...
Printer troubles: connecting via USB to Maxtor NAS
ensure that your notebook has all the updated drivers, if remote device is working and your notebook is not able to detect it. then there might be following issue. * your cable is faulty * necessary driver has not been installed on your notebook work around: check above options and try thanks arun
May 06, 2007 | Maxtor Shared Storage Plus (H24P200)...
Maxtor Shared Storage  II (S01R320) Hard Drive Logo
179 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
