Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave starts and runs but does heat anything up ?
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
7sty
Posted on Sep 30, 2010
Panasonic NN-H665BF starts and will run for about 5 seconds and then stops without heating up anything.
heatman101 [
Aug 07, 2011 | Panasonic NN-S541 Microwave Oven
Microwave is on but won't heat.
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
You can now purchase a new microwave for about fifty dollars at walmart so that may be cheaper than having a repair tech work on it.
Aug 20, 2009 | GE JE1540 Microwave Oven
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
Microwave won't heat anything
Yeah, it's time to invest in a new oven. The magnetron tube in yours most likely just finally wore out. It's the source of the microwaves, and like any tube it gets weaker with age and finally just quits altogether. It would cost more for a new magnetron than it would for a new oven these days.
May 15, 2009 | GE Microwave Ovens
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave will not heat
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Sensor Microwave Oven model JE1660
heatman101
yettu
Sep 07, 2008 | GE JE1540 Microwave Oven
Not heating up anything
Not knowing how much run time you have on the microwave , makes it hard to diagnose the problem but If everything appears to be working properly (as you describe) then you may have a bad/damaged or disconnected magnetron tube inside it. That kind of service should be done by professionals. Exposure to Microwave energy is not something you should mess around with unless you know what you are doing.. Good Luck
Aug 13, 2008 | Sharp R-820B Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
29 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
