Question about Tecnik TKC8525 Double Oven
Grill gets hot works for 5mins then switches off , cools down then comes back on.
  • 523 Answers
Change t stat
Posted on May 11, 2010
    Problem Solver:
  • 13 Answers
Check on the timer settings or adjust the timer on the grill,
Posted on May 12, 2010
How do I fix a continuously running upper oven fan
Without knowing the make and model, this is a guess, the fans usually run for some time after switch off, to allow cooling I am guessing this carries on until you isolate the mains. If so you have a thermostat problem. It would be easier to de-fine if there were more information.
Regards
John
Oct 31, 2014 | Ovens
Grill switching on and off
This is normal, the grill element is regulating, when the temp sensor is too hot it will switch off the element, when it cools past a certain point it will switch back on. If there is an indicator on the fascia panel this will switch on and off in conjunction with the element
May 07, 2012 | Stoves Premier 900GRa Gas Double Oven
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
The oven and grill when in use switch themselves off after a while. They will switch themselves back on after a while.
It could be the thermal cutouts operating. First things first, is the cooling fan running and does it turn off about 10 mins after the ovens/grill are turned off? If it isn't running then the unit is overheating and the thermal cutouts will operate. If it is running normally, then the cutout could be switching in early due to them becoming old and ineffective. There are two cutouts in the oven. One controls the main oven and the other controls the top oven. However, the grill operates without the clock being set, i.e. it is independent of the clock. So, if both the top oven and grill stop working together, according to the wiring diagrams in the handbook, the only thing it could be is the thermal cutout for the top unit.
F.Y.I. The top oven switch controls both the grill and the oven elements. In other words, in its OFF position, the Grill works and the Oven doesn't and in its ON setting the Oven works and the Grill doesn't. However, I can't see this failing as you specify, but worth checking if you take the oven to bits. The Grill will only work if the oven door is down.
If you need to replace the cooling fan, you will have to take the whole unit out of the kitchen cupboard to gain access to the top and rear oven panels, which have to be removed to gain access to the cooling fan and wiring. If you do replace it, ensure all the vents for air circulation are free from dirt and grease before you put it all back.
Try espares for STOVES spares. If the item is not listed you can ask them for a quote.
Be aware that the cooling fan is controlled by a timer circuit board and an in-line resistor on the fan terminal block. Either or both of these two and or the fan could have failed if the fan is not running! Any competent electrician should be able to work out what has failed.
All the diagrams are in the Handbook. If you need a copy, supply an email address and I will send you a pdf copy.
If you do ask for a quote, I suggest you ask for prices for all the parts mentioned above, so once you have checked what has failed, you will have enough info on pricing and availability as to whether to proceed or not.
Jan 18, 2011 | Stoves 720EF Electric Double Oven
My cooker keeps switching off during cooking even when the timer is not set, the grill does the same
depending on the make some ovens have a thermister where if the oven gets too hot it will cut out untill it cools back down, possibly the thermister is faulty.
Apr 06, 2010 | Ovens
I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
May 05, 2009 | Stoves 720EF Electric Double Oven
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Tecnik TKC8525 Double Oven Logo
238 people viewed this question
Top Tecnik Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
