Question about Tag Heuer AquaracerWAF1110.BA0800 watch
Hi, I've owned my aquaracer for 1.5 yrs and it has just started to run slow, I've had to reset it 3 times this week... does this run off a battery?
    President:
  • 2,501 Answers
I think it depends upo which model you have but the web site does not discuss this.
Generally, if it says "automatic" then it is spring driven (does it stop if you don't wear if for a few days?).
If it keeps going, when not worn then i is a battery driven type.
You can see the range of models on their web site http://www.tagheuer.com/the-collection/aquaracer/man/leonardo-dicaprio-ltd-edition/index.lbl?w=WAJ2116.FT6022. and you may be able identify yours from their list.
Posted on May 12, 2010
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have an aquaracer automatic and it gains up to 6 - 10 minutes in a day. I have had it fixed before and it was fine for 12 months and now it has started again. Is this normal?
All of the watches I have owned have run for many years without attention and when you buy one as expensive as yours, I would expect similar reliability.
I suggest that you speak to the maker (or contact them via their web site "Tag Heuer.com") and discuss your problem with them.
May 29, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Battery Charge Life 10 years ago, not being able to afford a real TAG, I purchased a 'replica' Aquaracer Automatic in Bali. I am happy to say that I am now the proud owner of a real Aquaracer Automatic....
If you go to http://ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf
you should arrive at the user manual for a Tag automatic watch which is similar to yours (an Aquaracer).
You will see that they claim 38 hour running when fully wound.
In view of the very small forces involved and the variations that occur in the manufacturing of the mechanism, I don't think that you should be surprised if there is a variation in running time.
If your genuine watch runs for a significantly less time thean they claim, you may have a reason to complain.
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
Second hand not sweeping but jumps at 5 secs intervals. Appears to be keeping accurate time.
When the second hand moves in short jumps rather than a smooth sweep or a second-by-second hop, it means that the battery is about to run out. Usually, with a week or two the watch will stop working altogether. You should go and have it changed as soon as possible.
Aug 02, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
I am unable to return to the 0 crown Position - TAG-CAF2112
The aquaracer has a 'screw-down' crown.  This means that the crown needs to be screwed in the reset it back to the 0 position.
Jan 09, 2009 | Tag Heuer Aquaracer CAF2112.BA0809 Wrist...
My Aquaracer Automatic doesn't keep exact time
you bought a automatic watch, they are a quality time piece, not an acurate time piece. if you want acuacy buy a cheap quartz watch.
Apr 07, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer AquaracerWAF1110.BA0800 watch Logo
521 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
