Question about Mitsubishi XL1U Multimedia Projector
The projector lamp will not come on. i have replaced the bulb and still no light. the power light flashes from green to red, the lamp light is orange and the temp light is red. any idea what the trouble is?
tinamarie49
  • 34 Answers
SOURCE: Hitachi CP-X250 LCD Projector
If both lights are flashing orange, that means that the bulb needs to be replaced and the filter needs to be cleaned. Make sure you reset the counters for both after you replace them.
Posted on Dec 05, 2007
SOURCE: Lamp turns off
The solution is a weird one. I had the same problem with my Sony Cienza VPL-HS1. Run for about 5 minutes and then the lamp would go out. The warning would show that Lamp/Cover was an issue. I assumed the lamp had reached its lifespan.
Wrong.
All it was, was the filter sitting in the filter box has a small trigger switch that turns off the lamp as a safety when someone inadvertently opens the cover for the filter.
Well, strangely enough, the box and the cover are sized in a way to expand when they heat up. (which they do aggressively) When they heat up they expand, and ever so slightly move the filter away from the switch far enough to trigger it to the off position (only about 1/64th of an inch).
Thats why when some of you tip your projector on its side it runs ok (gravity pushing the filter back in place).
The solution is to put a tiny strip of duct tape along the far edge (the edge opposite of the switch) of the filter on its plastic surround. This will snug-up the filter harder against the switch. Even when it tries to shift under expansion and contraction, it will not allow the switch to poke out far enough to turn off.
So, a penny of tape does the job!
JC Dallas Texas
Posted on Dec 22, 2007
marsrover
  • 682 Answers
SOURCE: Projector turns off after about 30 minutes. What's wrong?
your projector status means the protection circuit is working or the lamp is in an abnormal condition.
--wait until status indicator goes out and press power button.
---if the above solution is not working change the lamp.
Posted on Mar 18, 2008
SOURCE: automatic power shut off
Hold right left and power all at the same time and it will reset...
Posted on Feb 28, 2009
SOURCE: Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Posted on Mar 23, 2009
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Turn on the projector the power light flashes green with status as green then it goes to a flashing orange light
there should be a status for the lamp light; check to see if this one turns red. If it does count the consecutive blinks if it is 6 then replace the lamp
Apr 15, 2010 | NEC VT800 LCD Projector
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Mitsubishi XL1U Multimedia Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
