Question about Smeg 18 in. DWF409WH Slim-Line Free-standing Dishwasher
Burning smell from smeg DWF 409 dishwasher
Well, firstly my smeg dwf 409 ss dishwasher was at a rented house, they called and said that they smelled a burning smell from it and that the cycle didnt drain properly- so i took the machine away. When i plugged it in at home it drained and although it seemed to drain and be ok i didnt run a full cycle again i just put it in the garage, where it stayed for 18 months.
I went to plug it in the other day and it went BANG and tripped the whole house- is it worth repairing or should i admit defeat? I am technically ok and have taken machines apart before, but i dont want to waste my time if i can get a new one for a little more.
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
  • 1462 Answers
SOURCE: SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Posted on Jul 18, 2008
  • 93 Answers
SOURCE: Spray arms don't spin on Smeg DWF 410 ss
Remove he wash arms and visually check for obstructions in the holes where water sprays out if any number of these are blocked it will happer the turning of the arms
Posted on Jan 21, 2009
SOURCE: smeg dishwasher dwf 44 ss 1
http://www.smegtech.com/site/smeg/pdf_libretti/19590066100-GB.pdf
Posted on Feb 15, 2009
ginko
  • 19396 Answers
SOURCE: Machine won't drain fully
If the drain pump is working fine, and water flows from the machine and there are no clogged drain lines, then the problem is usually the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is too low then that is the problem.
Posted on Apr 07, 2009
Smeg dwf 409 ss went bang
is the power light on the board or a separate indicator?
were did the current go when the capacitor in the filter blew? probably into the board......
Oct 16, 2013 | Smeg Dishwashers
I've just been given a second hand Daewoo fuzzy logic DWF 4094R. I've been told it works fine, but it has a hose missing. This didn't worry me because I like to do cold water washes. But I
I don\'t under stand what help you need.
If the cat urine smell is outside of the appliance then wash it down with Clorox.
If there is a filter on the output of this machine then service that before doing the next step.
If the odor is inside the machine then run Clorox for a couple of long hot cycles AND then run white vinegar in it. The Clorox will sanitize and the white vinegar will loosen and remove minerals that hold odor.
Add a quarter cup of white vinegar to each load until the odor is gone or your clothes will stink.
My thought is that there is a reason they gave you this "working" machine. If you have further issues then let us know.
Good luck,
Mike
Feb 05, 2013 | Washing Machines
Detergent dispenser on SMEG DWF 44SS1 doesn't open during cycle - any ideas?
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Oct 18, 2009 | Smeg 24 in. DWI612 Built-in Dishwasher
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Jan 21, 2009 | Smeg 18 in. DWF410SS Slim-Line...
Manual for Hotpoint Aquarius dishwasher - DWF 34
hi
you want
Hotpoint Aquarius dishwasher - DWF 34 manual no.dont wory go to how stuffworks.comyou can get all info you want.please rate it
Nov 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Water pre-heating
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Open Questions:
See all Smeg 18 in. DWF409WH Slim-Line Free-standing Questions
Smeg 18 in. DWF409WH Slim-Line Free-standing Dishwasher Logo
366 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
