Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
The water temperatue indicates 150F. The water sensor is good. Does anybody know what the problem might be? I disconected the sensor wires and still reads 150F.
  • 8,404 Answers
The readout is defective ... replace it.
Never get in a hot tub that is above 105 ... and limit your stay to no more than 15 minutes at that temperature.
Posted on May 16, 2010
What would cause this? My dash water in fuel warning light remains on even though I have unplugged the sensor in the diesel filter.
It would stay on if the sensor is unplugged. That indicates a malfunction. Why would you unplug it? Have you drained your water separator? You would probably want to measure resistance on the sensor itself, to see if it is malfunctioning. Water in diesel is not a good thing. If you are sure the indicator light is telling you there is water when there is not, you may have a bad sensor or a short in the wire, etc. The reference voltage for most computer controlled sensors is 5V. I do not see what type of vehicle this is or what year, so my information is very limited. You do not want that sensor to stay unplugged though. ESPECIALLY IF IT IS A NEWER VEHICLE (96 & later). If the sensor is bad, replace it.
Mar 08, 2016 | Cars & Trucks
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
Where is intake temp sensor located on 2006 bmw x3 with m54 engine
I don't know, but if you look up the part it may show where it sits on the engine, or google up install temp sensor m54.
Mar 28, 2015 | 2006 BMW X3 3.0i
How do you replace an oxygen censor
Their is a special socket made just for this, your local parts store should know what you are talking about, price around $10.00 us. disconect electrical conector ,set socket over o2 sensor turn ratchet counter clockwise and unscrew o2 sensor. start new o2 sensor by hand so as not to cross thread it .tighten with socket and reconnect wires if this is helpful please leave me good feedback
Apr 06, 2013 | 2006 Ford Expedition XLT
We just bought a house with an AquaStar II solar pool heater, when we try to adjust the temperature we get a flashing check sensor error. Can anybody help us find the sensors or how to fix it?
On the Goldline controllers, the check sensor light flashing means the sensor on the roof is either bad, disconnected or shorted out. When the check sensor light is solid on, that indicates it is the pool sensor. Check the wiring from the controller to the sensor on the roof. If the wiring is not damaged, most likely you will need to replace the sensor. You can check the sensor with an ohmeter, it should register 10,000 ohms at 77 degrees.
Oct 02, 2011 | Water Heaters
I Have a 1992 dodge dakota And my temp gauge does not move. Do you know whats wrong with it
find temp sender turn key on and disconect wire from sender and earth it if guage moves to hot sender falty, if not guage faulty, or broken wire,or no power to guage
Aug 14, 2011 | 1992 Dodge Dakota
Hi, My Jetta3 cli guage is showing that the car is overheating. The electronic console unit reports correct temperatue 94 degrees. The car is using in excess of 14L/100km. This is attributed to the car...
May be oxygen sensor which also regulates fuel. That plus temp sensor is main inputs to fuel control. As 02 sensor fails computer can send wrong amount fo fuel and this will eventually burn up your cataylic convertor which will cause more problems. scanners are hard to come by on bosch systems but you need to get some info on voltages coming from 02 sensors and look for cross counts which is an indication of reaction times for the sensor. It should show movement from high to low voltage as the computer adjusts fuel. If the signal is staying in one range the computer will keep adding fuel thinking it is running lean. Hope this helps a little. If so please reply as this helps me continue to answer questions here and good luck
Apr 29, 2010 | 1995 Volkswagen Jetta
Where is the sensor located under the hood cause my low coolant light won't go off
hi, the coolant level sensor will be located near to where you fill it up with water it usually the cap that has the level in it you might see the wires coming from it, it will be located within the filler bottle so look for any wires near here.
Make sure the water isnt low and if you disconect this light you might get a water leak and never know and you could then blow the head gasket witch would cost 1000s to get put right.
Let me know how you get on or if you need further assistance ok
Nov 04, 2009 | 2002 Mercury Sable
02 sensors wiring
The yellow and white wires take any white wire.I dont now why they dont tell you that.And just fit black to black and grey to grey that simple good luck pippall.
Aug 08, 2009 | 1996 Jaguar Xj Series
Cooling fans not kicking in at high temperature.
problam could be with your coling temperatuer sensor .make sure fuse for you raditor fan is good.and you have coolant in you raditor.
May 20, 2009 | 2003 Audi TT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
113 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
