Question about Remington Polesaw Wizard
Chain fell off poll, trying to figure out how to put it back on.
  • 196 Answers
On the side of the saw where the bar (what the chain goes around/rides on) where it connects to the saw there are a couple nuts. Loosen them up, push the bar back towards the saw to put slack in the chain, wrap the chair around the bar making sure the bottom of the chain is in the groove on the bar and tip of the bar, then push the bar forwards away from the saw to take out the slack in the chain. Hold it tight and tighten up the two nuts. Depending on your model of pole saw, you may have only one nut and a plastic guide that keeps it straight. Same concept though. Loosen the nut, push bar in, put chain on, pull bar out, tighten nut.
If you've ever done it on a bicycle, it's the same concept. Loosen nuts on back wheel, push tire forwards and chain gets loose. Pull it backwards and chain gets tight.
Posted on May 11, 2010
How to put chain back on when it falls off
Almost every saw has a cover where the bar locks onto the saw, you take off the cover just as you do if you needed to remove the bar.
Just loosen the two or one bolts that hold the bar and slide the bar back, put on the chain and slide the bar back out.
Now there is suppose to be some play, the chain is not suppose to be very tight.
Here is what it suppose to be like.
Read this link that I post, it's easier to read this then me trying to explain it.
http://www.instructables.com/id/How-To-Tighten-a-Chainsaw-Chain/
Apr 14, 2013 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Replace chain on chain saw
Mary, you will have to loosen the chain tensioner all the way before you are able to get the chain back on. Also, with it all the way loosened start by getting the chain started over the drive end before you try putting it over the bar nose end. On some models you may have to as a last resort, remove the cover holding the bar on to get it on the drive sproket. Hope this helps.
Dec 02, 2011 | Garden
I have a 15 sp ultraterraine murry bike, and the chain came off, could you give me any advice on how to put it back, I have tried and tried, and soon as I turn the peddles, the thing pops off again, Thank...
If the chain broke and thus fell off the bike compleatly, take it to the bike shop for a SRAM master link to be installed. Should be about 5 bucks. If it is still intact but isn't on the gears, just shift to a gear farthest away from where the chain came off.
Jul 11, 2011 | General Cycling
I am a beginner, and I fell on my bike. the chain came off, which I replaced. However, I cannot change gears now. What is the basic for putting a bicycle chain back on?
Questions like these can be tacked into a search engine and voila - instant video answers.
"putting a bicycle chain back on"
Jul 03, 2011 | Cycling
Bought a Homelite 14" electric chainsaw. After
I am not sure if you have figured out how to put the chain back on your saw or not, but it doesn't take long.
1. Remove the plastic yellow "T" shaped nut on the right side of the saw (towards the front of the motor housing)
2. Remove the black plastic housing that covers the rear section of the bar and chain
3. Place the chain back onto the bar making sure it is facing the correct direction.
4. Place the chain over the rear sprocket area
5. Turn the +/- yellow plastic knob (towards the back of the saw on the right side) in the - direction until the metal guide inside the plastic casing lines up with the hole in the chainsaw bar
6. Replace the black plastic housing and slightly tighten the yellow "T" shaped nut.
7. Now turn the +/- knob until the chain is tight. Once the chain is tight, turn the "T" nut until it is tight and you are ready to cut again.
Jan 30, 2011 | Homelite Consumer Products 9.0 Amp, 14 In....
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are...
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Jan 01, 2011 | Toys
Dhain fell off lost a nut, took it apart put the chain back on
ARE YOU ADJUSTING THE BAR OUTWARD TO TAKE UP THE SLACK IN THE CHAIN?
Apr 29, 2009 | Remington Garden
Chain fell off how do i put it back on so it will stay , i took
Either you are putting the chain on backwards or you are not tightening the chain
Apr 29, 2009 | Remington Electric Chain Saw
Twisted Chain
Take the back wheel off and straighten the chain. Be careful to keep it straight while putting it back on. Try and oil the chain first.
Apr 24, 2009 | kawasaki 73026-9 KDX126FS Dual Suspension...
Remington Polesaw Wizard Logo
164 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
