Question about Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
I'm having electrical serges going through my Behringer DJX700 Por Mixer. After turning it on and off 10 - 25 times, it seems to go away until I go to use it the next time. Can you please advise on how to fix?
    President:
  • 1,851 Answers
I can't be sure what you mean with "serges". I think that you mean that you "hear" spikes generating in the switch. In that case unplug the mixer and use a Contact Cleaner spray (you can ask for it at any Radioshack or other like this shop) in order to clean the inner contacts of the switch. So spay in the gap between the power switch (at the back panel) and the plate around the switch and turn the switch on and off for some times in order for the spray to clean the contacts of the switch. Leave the device some minutes to calm and the sprayed area to evaporated and check the results. If the problem remains, you have to change the switch because the contacts are in a very bad situation.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 11, 2010
Behringuer pmp 5000 turns off
Can you elaborate a bit more about what you mean by "turning off?" What are you doing up until that point? Does it do it at certain times, etc.?
Apr 12, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Where can i get a replacement assign knob for a djx700
Behringer fired their USA distributed a few weeks ago. You'll have to call Behringer directly and request the part. Or email.goto th website
Nov 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Frustration coming from djx700 mixer left Chanel need help :( on booth and master ??
the faders were actually fails functioning it well, it must be replace a new one!im a audio technician of BEHRINGER!
Aug 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
My behringer djx700 does not work properly 2 use the effects u have 2 plug an rca into the booth output on the back but then nothin else works and i can only here my left turntable in my head phones there...
Semiconductor things involved with sending the booth signals into the mains are:
IC2 which is a 5241 gate controlled by MIC_ON.
IC30 4580 summer for MIC and BOOTH.
IC53 4580 inversion and gain control.
IC39 4580 MAIN output drivers.
May 13, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Monitor Cue problem
If you don't have the manual it is here:http://www.behringer.de/EN/downloads/pdf/DJX700_P0165_M_EN.pdf Have a look at page 4 under Monitor, mode switch and mix control. You might be having problems with them.
Feb 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Djx700 Headphone (cue) Problem. Please help.
Have a look at page 4 of your manual under the Monitor section, mode switch. Manual is here:http://www.behringer.de/EN/downloads/pdf/DJX700_P0165_M_EN.pdf The mode switch may be faulty or the mix control may be faulty.
I need a wiring diagram for the main circuit board in a behringer djx700 mixer
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Aug 26, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Faulty effects behringer djx700
The effects on the PMP powered mixers flash UNTIL you push in on the selector knob. This way you can dial in the next effect number and then push in later to activate when you want it... Could yours possibly be the same technique?
May 16, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Effects button not working!!!!
Most likely the fuse for the effects circuit has blown, which happens sometimes on mixers with built in effects.
You'll have to open the mixer as the fuse will be inside the mixer on a circuit board (look around inside where the effects part of the mixer is) replace it with an identically rated working fuse and you should be done.
Apr 24, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter Logo
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
