Question about Sharp AR-M550N Copier
Is it possible to "lock out"trays 3 & 4 on a Sharp AR-M550N, so they can not be used by everyone? If so, How?
  • Sharp Expert
  • 1,326 Answers
Yes, in user settings. Under paper tray settings. I don't know why you would.... But you can also change the paper size to a odd ball size too.
Posted on May 12, 2010
Sharp AR-M550N close the upper left side cover
Close the lower left side cover error :
this problem is for under the left door
for fix this problem push the all part on left side
under the door is important
mehdi ebrahimi iran,karaj
Oct 19, 2012 | Sharp AR-M550N Copier
Sharp AR-M Error CODE E7-02 - How can I fix this?
this is occur due to LSU (laser diode,reception element,apc circuit )trouble or LSU drive circuit (asic) trouble.
1.first go to service mode (simulation mode)& reset it
2. still error occurred, check wire harness of laser unit & clean laser unit mirrors,reflector polygon mirror.
3. still occur just replace toner cartridge because once it works for me.
4. finally replace laser diode.
May 24, 2011 | Sharp AR-M550N Copier
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
Feb 01, 2011 | Sharp AR-M550N Copier
Sharp AR-M550N control panel 'locks up' intermittently
loose the panel and service it one or more othe switch is not active
May 20, 2010 | Sharp AR-M550N Copier
Reducing on an AR-M550N
You can download a manual from http://www.sharpusa.com/~/media/813980603C1E4072A9071108E8971025.ashx?cop_man_ARM550_620_700.pdf
Jan 05, 2010 | Sharp AR-M550N Copier
Tray 1 paper not recognized M620n
Are you getting a error code? I would look behind the paper tray for a piece of paper behind the tray? Good Luck
Nov 15, 2009 | Sharp AR-M550N Copier
What does it meant when the copier has message Load 81/2 x 11 paper type:user type 1
The tray that the copier is attempting to pull paper from is empty. You may have a tray with 8.5 X 11 paper, if you have more than 1 tray, but it is looking at an empty tray.
May 11, 2009 | Sharp AR-M550N Copier
Sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
Oct 06, 2008 | Sharp AR-M550N Copier
Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Mar 26, 2008 | Sharp AR-M550N Copier
Sharp AR-M550N Copier Logo
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
