Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Wire going to prop of Motorguide trolling motor shorted
Bow Mounted, 12 Volt, 5 speed, 46 lb thrust, (fw46fb) foot control, Motorguide trolling motor. Wire shoted going down shaft to foot, speed 1-4 no longer work but speed 5 does work. How do i FIX IT.
    Problem Solver:
  • 6 Answers
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
  • Earnie Olin
    Earnie Olin Mar 25, 2013
    Kudos to Master Mechanic. This is the right answer. Not easy, but doable. Don't waste your money on a speed switch.
  • Earnie Olin
    Earnie Olin Mar 26, 2013
    Master Machinist*
    Problem Solver:
  • 5 Answers
Great white wont turn motor runs but wont turn
Do you mean you can hear the motor turn but the propellor doesn't turn?
Then check the break-pin of the propellor. It's a security device that will break when the propellor hits an object in the water...
Sep 27, 2016 | MotorGuide Great White Saltwater Series...
My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
Dec 16, 2015 | Boating
I nned a motorguide 46 lb. thrust electric foot controlled trolling motor manual
Go to http://www.boats.net. Let me ask you a question, is it 5 speed? And if so have you lost some or all speeds but 5?. I so, them you need to take the lower unit apart and you will find solder laying in the bottom. You will see that the speed control coil wires at one if the terminals on the brush board has no solder. Clean it up along with the wires so that you see copper and re-solder. This is due to poor quality control on soldering at the manufacturer. When you re-assemble tighten the bolt 45-50 in-lbs only. No more.
Oct 02, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
607 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
