Question about Cameras
Do I have to add memory before I use it? I just can not work this camera no matter how much I read the instrustrions. help
  • kakima May 11, 2010
    That depends, some cameras have internal memory and some don't. Can you tell us the make and model of your camera?
  • Ty Price May 11, 2010
    You have to tell us what kind of camera it is.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Jun 15, 2010
How do I fix my Olympus VG-120? It freezes while recording video and taking pictures. What could be causing this?
Memory cards have different write speeds. When making a video it's best to use a series 10 card. This number has nothing to do with the capacity of the card but does have a faster read/ write speed.
Dec 05, 2014 | Olympus Cameras
No matter what card we put in the camera, it always read locked and will not take pictures. please help!!
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 16, 2011 | Canon PowerShot A650 IS Digital Camera
Reset switch on memory card how do i do this
An SD or SDHC memory card has a protection switch on the side I'll add a diagram to show the correct position. It needs to be pushed ahead towards the top edge closes to the gold contacts. once this is done insert it carefully into the camera and then format the card in the camera.
Formatting allows the camera and memory card to communicate between each other. Also after downloading pictures to your computer format the card again it cleans the memory card and makes it compatible with the camera.
Diagram doesn't matter that it has Kodak written on it the SD card switch placement are the same
Jan 08, 2011 | Kodak EasyShare CX7530 Digital Camera
Computer does not respond to camera being on and plug in
  • Start EASYSHARE Software.
  • From the menu bar, select Help > About Kodak EasyShare software.
  • Note the software version. If you have Version 8.0 or later installed on your computer, review the help information for Transfer Pictures.
  • From the menu bar, select Help > Kodak EasyShare Help.When the Welcome to EasyShare Software window appears, select Transfer pictures, then read the help information.
  • If you do not have Version 8.0 or later installed on your computer, go to EASYSHARE Software Downloads, then follow the instructions to download the latest version of software. Approximate download time is 5 minutes for Cable/DSL, or 2 hours for a dial-up connection.
If that doesn't solve your problem you can manually add your pictures/videos to easyshare software.
  • In easyshare Software, select My Collection, then select Add Pictures. The Add Pictures screen appears.Look at the Select a location field. If the My Files folder is collapsed, click the + to open the folder.In the Select a location field, select your camera folder, for example: M381 Digital Camera. Thumbnails of the pictures/videos on your camera internal memory, and on a memory card if one is in your camera, appear.
  • Select the pictures/videos to add to EASY SHARE Software, then click Add Pictures. To add all the pictures/videos in the folder, click Add Entire Folder.Click Done.
Thank you !!
Jun 25, 2010 | Kodak Easyshare C813 Digital Camera
Pc wont recognize camera. windows xp
Thank you
Jun 23, 2010 | Kodak EASYSHARE M340 Digital Camera
My computer won't recognize my camera. All of the USB ports are working (I checked them with other devices) but none of them are working for the camera...
Thank you
Jun 11, 2010 | Kodak EasyShare M1033 Digital Camera
We have tried several memory cards in our camera. No matter what type, after we format it, the camera will NOT read it! Help!
do you format it in the computer? or on the camera? have you tried formatting the card on the camera, through the computer? is it the right kind? backwards?
Jan 02, 2010 | Nikon COOLPIX L100 Digital Camera
Won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Nov 03, 2008 | Kodak EasyShare DX7630 Digital Camera
Card Error message
Your card may have become corrupted, there are good free utilities out there to save such files from corrupted memory cards, try DIR (Digital Image Recovery) that you can use with a computer card reader if the computer does not recognize your connected camera as an external hard drive.
If you were able to recover your files, format the card in the camera, that should solve your problem using the card.
If the card cannot be recognized by the computer or formatting the card doesn't help, you may have a defective memory card, try another one.
If the card works otherwise but is still not recognized by the camera you may have a defective memory card connector or other camera motherboard problem, sorry.
Hope this helped...
Sep 01, 2008 | Fuji FinePix S602 Zoom Digital Camera
No memory card
Did you check the slot to see if any of the pins are bent?
Jan 25, 2008 | Canon PowerShot A80 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
