Question about HP Officejet Pro L7680 All-In-One Printer
My printer won't turn on and everything is plugged properly
  • 74 Answers
In that case please follow this step
1) Power Code Check first if its working not perfectly so please change it.
2) if Power Code working fine then other thing is that may be some problem with Printer Hardware may be due to short board its not working need to repair this.
Posted on May 11, 2010
Why doesn't it turn on?
Check all wires and connections. If u confirm power reaching the innards of unit then there is an issue with the power supply of printer.
Mar 12, 2016 | Canon Pixma MP500 All-In-One InkJet...
Monitor won't turn on I have connected everything properly and still no signal
I didn't see whether the power strip where you have all devices plugged in was turned on. Plus, you only showed one side of the monitor. There should be an indicator light on the monitor which indicates that electricity is running through the unit. Lastly, did you read the owner's manual before putting this unit together? Check all options and let me know what happens.
Mar 06, 2013 | Computers & Internet
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Trying to get my lexmark x6650 set up in my new home. I have all the cables plugged in but it won't turn on.
Have you verified that all of the power cables are plugged in? Try plugging it into a different outlet. There may also be a separate power button on the printer besides the one on the top. If you have another power adapter, try that as well. Make sure that you can plug another device into that power outlet and it powers up properly.
Thanks for using FixYa!
Aug 08, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Why won't my printer let me scan my document to the computer?
Could be a number of things. I would suspect an incorrectly installed printer program. I'd uninstall the printer software and restart the computer and then reload.
If the printer is a HP, don't plug it in until the software tells you to. Otherwise it won't work properly.
Aug 02, 2011 | Computers & Internet
Carrier jam
To fix the carrier jam, open the printer cover. Remove the cartridges from the carrier. While the cover is open, check inside for any loose transparent strip - the encoder strip. The encoder strip ensures the proper mechanism of the carrier on the assembly. If everything looks fine inside the printer, close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and make sure they are properly inserted and secured in the carrier.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
It won't turn on. I have it plugged in and everything.
It sounds to me like your power supply went out? I hope this helps !
Jun 03, 2011 | Dell 1600n All-In-One Laser Printer
Printer does not turn on
Change the power lead, the fuse could have blown or the lead could be broken. Also check everything is plugged in properly and turned on at the wall.
Mar 08, 2011 | HP OfficeJet 7410 All-In-One InkJet...
My hp psc 1410 all-in-one printer wont turn on..Everything is plugged. When i was scanning it said was not able to scan try again or cancel. i clicked cancel. then I switched my printer off and when i...
try connecting the Printer to different wall socket or on surge socket, this could be due to low supply of electricity
check the Cables connectivity properly.
let us know if this fixes the issue or not.
Jun 23, 2010 | HP PSC 1410 All-In-One InkJet Printer
The printer will not power up. Everything is
If no power, try to check the plug fuse first.
Sep 09, 2009 | HP PSC 2110 Color Printer
HP Officejet Pro L7680 All-In-One Printer Logo
143 people viewed this question
Seeker5211
Seeker5211
