Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Will not spin and makes grinding noises.Lid switch seems fine. Stopped my a parts place for a manual and they said it was the coupler. How and where can I find that on the machine?
I need help to get to the motor
Posted on May 12, 2010
    President:
  • 949 Answers
It does sound like the coupler, here is a link to some instructions I put together to replace it. Let me know if it helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
Posted on May 11, 2010
LXR7244PQ0 whirlpool top load washer. Problem: Agitator spins when manually turned, wash fills, does not agitate, spin, or drain. I checked lid switch, couplers and rubber piece is fine on motor I have...
Sounds like the motor coupling is bad- it keep the motor and transmission safe when overloaded and its cheap, if the motor is making noise that's the place I'd start. After that it's the motor (make sure it has power when it should) or the transmission- both not cheap.
May 16, 2014 | Washing Machines
Whirlpool ETW4100SQ washer. Unit stopped agitating, grinding noise appeared. Tub is loose, agitator is free, was able to empty the drum.
while your washer will draining, in addation to the noise during the agitate cycle is it making a similar noise during the drain/spin cycle?
if that is the case the motor coupler is broken
i have attached a youtube video that will show you step by step how to replace the coupler
http://youtu.be/9K1KHEogf3c
the part number indicated in that video is the exact part number for the coupler
GOOD LUCK,
GENE
Jul 26, 2011 | Washing Machines
Roper rab4132hq0 washer does not spin consistently. Most of the time, the spin will not engage, this isn't just for the spin cycle, but for the spinning during the wash and rinse cycles as well....
Sounds like a bad gearcase.You have a machine that is direct drive. The motor is hooked directly to the gearcase by a little coupler. Look under and make sure the coupler is in place if it is then you need gearcase.Again the coupler is located between the motor and gearcase. Hope this helped.
Jun 04, 2011 | Roper Washing Machines
My kenmore washer will not spin what could be wrong just replaced the water pump
If its making noise when you put the lid down like a grinding then its probably your coupler unless its a front load. If its completely dead check your lid switch. If you click on my profile and go to my tips I have complete instructions for checking and replacing your drive coupler.
Good luck _MJ_
Mar 07, 2010 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
WILLNOT SPIN OR AGGITATE/IT WILL DRAIN
Just because the rubber part of the coupler isn't shreded doesn't mean that the plastic parts are not broke... There are three stems that protrude from the plastic parts of the drive coupler,and mesh with the rubber section of the coupler... the stems may be broke off... If you smell rubber burning then I would say almost 99% of the time it's a bad drive coupler...If the coupler is not broke and the rubber section is alright then you have a bad transmission... Most likely the main drive gear is bad... Since you said that you can spin the tub by hand, indicates that the brake system is alright, and nothing is caught between the inner and outer tubs... You can rule out a lid switch problem, cause the washer would agitate even with a broken lid switch, but it would not spin..since the machine make any kind of different sound when you run it Like a high pitch squeal or grinding noise?
check the lid switch see if it's not broke... wasn't the lid switch, but I got to thinking it will agitate at the first part of the wash cycle, but when it goes into the slower speed wash, if your lid switch is broke, then it won't agitate or spin...
Feb 10, 2009 | Kenmore Washing Machines
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Whirlpool LSQ8543JQ1, washer stopped full of water, will not start back up, seems like no power to it, check fuse box and everything else that is running of same.
Pretty much exactly what guest above me said. I have a lsq8543jq1 also, was stopping after agitation.
At first thought it was something more serious, since the dial seemed to make a humming/grinding/buzzing noise when it was switching to agitation cycle, but that seems to just be a timer before the drain/spin cycle kicks in.
I had a washer full of water, so rather than wait till I could get a part (or hand drain -what a pain), I just grabbed a paper clip and rigged the switch so it thinks the door is shut and voila, drains and finishing cycle as I type.
The switch is a safety device to prevent accidents; bad injuries could result if the door is opened while the washer is in spin cycle. I don't recommend this as a long term solution - especially if you have kids. I have 2 and will be ordering the new part asap.
Apr 06, 2008 | Washing Machines
I have a kenmore 70 series washer,the machine won't spin. I hear the clutch but it's not engaging. The pump to remove the water seems to be operating but the tub just won't spin and makes a loud noise.
The loud noise (sounds like rattling or grinding) is the motor coupler. It's between the motor and the transmission. This part takes the place of the belt, and costs about $20.00.
Mar 31, 2008 | Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
