Question about HP Pavilion A700N (PJ516AA) PC Desktop
I installed a SATA to replace the parallel hard drive that came with pc and now it doesn't recognize the optical drive.
  • pburney May 11, 2010
    Your solution was perfect. All related problems were user problems. The drive is working. Thanks for your help!!!
  • 4,281 Answers
First open cpu cabinet and reconnect both connection of optical drive power cable and data cable.
Then if still same issue then follow below.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall cd/dvd drive drivers.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
I
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 11, 2010
  • 1 more comment
    No Luck. It encountered problems trying to delete upper and lower filters
    Actually, I don't think anything happened when I typed in devmgmt.msc. All it did was open the device manager.
  • Yes in device manager locate cd/dvd r/w driver right click on it then uninstall.
    Then locate the above key in registry.It ask for delete upper filter and lower filter delete both then restart computer then you can see your drive.
    Also reconnect both connection to optical drive and set it as master with jumper settings.
    Change try the another ports of motherboard where cable from optical drive conected.
Driver download
Driver not required to install. Your BIOS should recognize the drive
Jun 30, 2013 | Western Digital WD Scorpio Blue WD5000BEVT...
Hello, What is the largest hard drive I can upgrade too for my Biostar 330G? Can I use a SATA and install a IDE hard drive as my slave backup? Thank you. Remi
As I recall, this model has one IDE channel on, which typically powered an optical drive. The manufacturer claims that it supports one IDE drive, in theory, you could set the IDE HDD on the second connector of the IDE cable (secondary slave), however, it may be that the Bios will not recognize this.
My own thoughts would be, as this has 2 SATA ports, to leave the IDE connection alone and for the Optical drive and put another SATA HDD on the other SATA connector.
If you need to use the IDE drive, you can get an IDE to SATA adapter and that would enable you to use it connecetd to the SATA connector
As to capacity, I'd assume it would run any size of HDD
Jun 23, 2011 | Biostar iDEQ 330G (IDEQ330G) Barebone
Hard drive replaced. But does not recognize hard drive. Old hard drive but back But does not recognize hard drive.
open the CPU and check whether it properly connected (both the wires sata cable and power cable)
then check in BIOS. is it detected if it is then change the boot device priority..
if its not detected then try to swap the wires with optical drive..
still not then change the HDD
Mar 28, 2011 | HP m7170n PC Desktop
I need some help...A friends laptop is very messed up, i need to install his SATA Hard drive on my computer. I have a SATA Hookup on it, its all hooked up, but WindowsXP is not recognizing it. My brother...
Hi
Thank you for your query
From what you are describing you are missing the SATA controller
Please do the following
1) Go to www.devicedoctor.com and download and install application
2) Once installed load up and click on begin scan
3) Once it has scanned it will probably pick up missing SATA controller and give you the option to download
4) Download the SATA controller and install
5) Reboot PC and the SATA drive should be recognised
Mar 12, 2010 | EliteGroup P4M800-M7 Motherboard
I have a hp pavilion dv 1659 us (dv 1000) the sata drive goes bad
It will recognize the new drive if you were able to "migrate" your data from the old drive. If not, you can clean install by booting from an optical drive (changing your boot order at start-up) and using a new OS disk or your recovery disks. You might be able to perform a remote partition & format and install from one drive to the other with USB external enclosures for each drive and another computer (depending on the 100G drive's condition). I hope this helps.
Feb 23, 2010 | HP Pavilion dv1000 Notebook
New hard drive not recognized on mac pro
OK what you could do is connect up that drive to a PC and format it with NTFS, & then put it on the Apple, it should then "See" the drive.Then you can work on it via the Apple.
Jan 29, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
How do i hook up lg/gh22 super multi dvd rewriter to my dell dimension 3100 The cords are not the same
The drive you are installing is a SATA drive. The system came with a PARALLEL ATA or PATA optical drive, The motherboard has a SATA controller and the HDD is a SATA drive. So you need a SATA data cable and connect it to the SATA 1 port on the motherboard. There should be a SATA power connection inside the chassis that is not being used, that you can connect to the drive. Then go to system setup (F2 at boot) enable the SATA 1 controller and disable the PATA controller
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1043338
Oct 05, 2009 | Dell Dimension 3100 PC Desktop
I have to replace the hard drive in a thinkcenter s50
Remove harddrive make sure it is set to master. while hard drive is out boot up computer it will boot to the motherboard. Find the boot menu and set your cd drive as the first device. Save and shut down the computer. Install your hard drive now boot up and as soon as you can insert disk.
Sep 21, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Adding a second hard drive
Sorry ,You can't add SATA hard disk...As ur motherboard don't support it...
Nov 29, 2008 | Computers & Internet
Motherboard fails to see Hard Drive...please help
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
Mar 23, 2008 | Dell Dimension 4600 PC Desktop
HP Pavilion A700N (PJ516AA) PC Desktop Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
