Question about Toshiba Televison & Video
Service code for ctv microprocessor Toshiba 8893cpcng6uro ,
I want to adjust height , agc & want to put logo name to a ctv board / chasis JY - 2168B V1.2 (Chinese make) , which i purchased from local market
2 Suggested Answers
mie999s
  • 105 Answers
SOURCE: service code on remote to adjust the vertical
if you cannot get a code go and fine up same tv remove the memory ic and use ic copier to duplicate the ic from good tv
Posted on Jun 07, 2009
Vertical section adjustment of Bpl CTV .model cv29af2c_00.tell me service mode code.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 25, 2015 | Televison & Video
I have a picture noise problem on light scenes how can I correct it
Noise in picture occur due to 2 main reasons.
External interference to video signal & improper AGC [Automatic Gain Control].
Check whether the signal cables used are of good quality; connections are firm and no electrical instrument which produces RF interference is placed near to the TV
The AGC problem can occur, if the AGC circuit at the main board is faulty, or it has not been adjusted properly. In this case, I suggest to contact any service technician; or the authorized service center for Panasonic. To adjust the AGC; you have to enter the service mode to the TV; and it is somewhat a semi-skilled work.
Dec 24, 2014 | Panasonic VIERA TX-P50G30B 50AAAA€AA...
What is service mode sansui ctv k2k 21-v
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 18, 2014 | Televison & Video
How my toshiba tv sceen light up but no picture 40rv525rz
Main board fault. Contact any service technician or the authorized service center for Toshiba. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 06, 2014 | Toshiba 40RV525R 40 in. HDTV
Is there a hidden service setting to adjust vertical height of picture as what ever ratio setting is used set over scans been like it since new but never got around to fixing as it was a second set only 13...
With most modern CTV sets, there is a service mode to adjust all the parameters to picture all other. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 21, 2013 | Televison & Video
Height adjustment not working.
It's likely the circuit board that controls the height adjustment motor, or the motor itself. Your local sebo service center will be better able to test to see just what is wrong. Though it wouldn't hurt to take a look at the boards sometimes they're visibly burnt, or connections can be loose. Good Luck!
Feb 16, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
Tamil nadu free ctv remote service mode
service mode tv Audio Ton CTV 5502 Service Mode
Audio Ton CTV 5502
10.3 90° MONO CTV Service Mode;
Press UP & DOWN buttons together on tv's
local control and then switch on.
Jan 07, 2011 | Televison & Video
How do you get the set into Service mode to adjust
try the zoom button on the remote or go into your menu and see if you can find something there
Feb 13, 2010 | Televison & Video
Changed chips and now no picture
When I changed the STK392 chips I had no pic on startup also. I don't know why but I found 2 6.3 amp pico fuses blown on the front edge of the power supply board. They are marked on the bottom of the board. I had to fudge some pigtailed AGC size fuses & the high voltage & video started..jim
Aug 29, 2007 | Toshiba 43HX70 43" Rear Projection...
Televison & Video Logo
297 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
