Question about GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White
Water runs out of dispenser on door - can't shut off
Got a new PSI235gmd about 9 years ago. Had numerous problems over the years. The latest is one the repair person can't fix. From time to time (ntermitant problem), the water runs out of the dispensor on the door after I fill a glass. Just keeps running out. I have to pull out the refrig and turn off water in the wall. Later, if I turn it on again, everything works OK for awhile, the same problem again (maybe months later). Physically pulling out the little water lever does not stop the water.
  • wreace May 12, 2010
    someone suggested it might be a spring, but don't know what spring, and don't think that would cause "intermittant" error --
    Any other ideas?
  • 6,784 Answers
HI, Ok, if this leak is coming directly from the water outlet line at the dispenser section, this will be the result of a damaged inlet water valve assembly. There may be some hard mineral build up in this particular valve assembly that is causing the valve to not close properly. This build up will damage the solenoid based valve assembly, thus creating the small continuous leak at the dispenser. Use my procedure to correct this issue.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink or behind your unit). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (dont pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms(standard). A Close inspection of the inlet valve and especially the coil, may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on May 12, 2010
  • wreace May 14, 2010
    This was a good (and potentially helpful) suggestion. Unfortunately, I couldn't wait this long. I went to a local dealer on the 11th (Tuesday), discussed the problem I was having, and ordered a replacement valve.
    I installed the valve earlier today (before I saw this note), and the problem appears to be fixed. The old valve was making a lot more noise, and the dealer thought it probably needed replacement. The new one is much quieter, and so far, works just fine.
    Since I didn't get the answer from FixYa, I should not be billed.
  • Michael Masters
    Michael Masters May 14, 2010
    You will need to take this issue up with our support staff. i submitted my solution immediately, and you were alerted, via e mail notification. I completely posted the correct solution to your issue. this was quite easy to solve, due to the fact that you explained your issue well.
    Have a great day:)
  • 11,896 Answers
The spring may be streched or loose or has fallen off or getting caught on something.
Posted on May 11, 2010
  • 1 more comment
  • wreace May 11, 2010
    What ring? If it was stretched or loose or fallen offm then wouldn't be intermittant problem...
  • Nate Stansfield
    Nate Stansfield May 13, 2010
    This is usually a defective shut-off valve. You will probably have to
    replace it.
    It may also be ice crystals in the line. Run the water for a long time
    until it is no longer cold. If the valve does not leak, replacing the
    valve will not solve the problem. You might find a temperature setting
    that is a good compromise.
  • Nate Stansfield
    1. Insert
      a glass into the water dispenser as if you wanted to get some water.
      Can you hear the pump running when you press the paddle with the glass?
      If so, that is a good sign. That means the electrical and mechanical
      parts are working. The problem is most likely a blockage somewhere in
      the system.
    2. Step 2
      Check the water filter. It is usually located in the back of
      the refrigerator under a plastic cap that screws off. You may want to
      move objects in the refrigerator away from where the filter is, because a
      little water might spill out when you take off the cap. Pull the
      filter out with your hand and examine it. Does it look dirty or
      contaminated? Has it been along time since you last changed it? If so,
      you might want to try replacing the filter with a new one. If a filter
      is dirty enough, it could prevent water from passing through. In such a
      case, you would likely have noticed a gradual drop in the output of
      water before it stopped completely. If this is not the problem,
      continue to the next step.
    3. Step 3
      Get a hairdryer and plug it into an outlet that is close
      enough to allow you to use it inside the refrigerator.
    4. Step 4
      Open the door and locate the area directly behind the water
      dispenser. You may need to remove some items from the surrounding
      shelves. Very often, the problem is that the water in the lines in the
      door have frozen solid. This is especially likely if you have been away
      for a few days in the winter, and you turned down the heat. The
      combination of the lower temperature, and the fact the the dispenser is
      not being used, can cause the lines to freeze up.
    5. Step 5
      Turn on the hairdryer and set it to medium heat. Slowly wave
      it back and forth around the back of the door behind the dispenser. Then
      do the same around the front of the dispenser. Continue alternating
      between the front and back of the door for 15-20 minutes, and
      periodically try the dispenser to see if it starts working again. If you
      have no luck after half an hour, then the plug of ice might be deeper
      in the system. Go on to the next step.
    6. Step 6
      Ask a couple of neighbors, or friends who live nearby, if
      they would let you store your perishables in their refrigerators and
      freezers. Once the refrigerator and freezer are empty, unplug it, and
      let it sit, with the doors open for 24 hours. Then plug it back in and
      try the dispenser again. It should work by now. If it still does not
      work, then the clog is not ice. You will have to call a repairman to
      purge the lines, or to otherwise solve the problem.
    jQuery('.article ol .image').each(function(i,e){
    var $this = jQuery(this);
    $this.find('img').error(function(){
    jQuery(this).remove();
    $this.remove();
    }); http://www.PartSelect.com/Entry.aspx%3FB...">
What controls the water dispenser? It works but takes about five seconds to shut off.
You have a problem with relay and needs to be replaced. I did on mine about 2 years ago. The other possibility could be the shut. Off valve not stopping the water immediately.
Mar 13, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
No water/ice dispensing
I would make sure all the doors are completely closed. If you can't completely close one of your freezer doors, you may have ice built up behind it. Take your freezer bin out and see if you have to defrost.
Mar 06, 2017 | LG LRSC-26922 Side by Side Refrigerator
Icemaker flap door doesn't shut completely resulting in in frost layers forming on and around ice bucket and water leaking into the drip tray and ice forming on freezer door near the freezer door.
I found 9 different model to your model number, but all the unit use the same dispenser components.
Below there is a picture of the dispenser, item number 4,5,6,7 and 8 all deal with the working parts.
4 - return spring 5 - pin 6 - dispenser door 7 - Door Mechanism Assy (this one has a heater, not really needed) 8 - Door Delay kidlmo_2.gif but in looking up history, I found a complete door kit that should solve the issue. They came out with a part 8201649 and this part contains all those item and a bracket that can fix the broken tabs that the pin sits in. That was more common.
Back a couple of years ago they stop telling customer that the repair was not possible when the bracket to the pin support (mount) would break.
I hope this helps..
Jul 15, 2011 | KitchenAid KSRG22FKSS Side by Side...
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Have the same problem with the water dispenser
Just went through the same thing but mine is a Frigidaire (Electrolux). The tube within the freezer door was frozen up. There is a connection behind the left corner of the front grill that can be taken apart. I put the end going to the dispenser into a pan of hot water for about 15 minutes and got flow back. I just hope it will work again in the morning.
Feb 12, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Refrigerator model #gss25sgress Water dispenser problem
What you describe was a common problem with this model and one that still pops up. Your refrig *might* qualify for an upgrade under terms of a program GE initiated a few years ago. Call 800-432-2737 first it might save you a service call
Jan 06, 2008 | Refrigerators
Water dispenser won't turn off
Stix: Check behind the dispenser handle the switch or button which is responsible to activate the mechanism of water dispensing. If the switch or button is covered with a reubber you must remove the rubber cap or whatever cover it has. If you have mineral oil or somekind of greasy stuff (vaseline or something similar) lubricate the switch or button. Open the freezer door and activate and deactivate the dispenser several times to lubricate the whole mechanism. SithPitt
Jul 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White Logo
52 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
