Question about Ridgid Compressor With Toolbox On Top
Rigid Compressor with nail gun. problem won't recycle or kick on. I have to bleed air to 40 psi before it kick on
    President:
  • 1,509 Answers
The pressure switch is out of adjustment, it could have vibrated that way. It's the box the govener linage hooks to. It could be bent too. The pressure valve still works as it will kick in at the lower than normal pressure. The pressure swith may have to be replaced if it won't adjust.
Posted on May 11, 2010
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
Misfires new gun
If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Mar 24, 2014 | Hitachi KNR90AE Round Head Framing Combo...
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Jan 17, 2011 | Air Tools & Compressors
I want to use a 120psi brad nail gun on a clarke ranger 115psi compressor ..will it be ok
It'll be perfectly fine. Wear safety glasses with them nail guns, they can really send a nail flying.
lp
Dec 29, 2010 | Clarke Power Products Clarke Pioneer 2 Hp...
Adjusting airpresure
There is nothing on a nailer to adjust the air pressure. You have to do it at the pressure regulator. It is feasable to mount a regulator at the gun but more likely it's on the compressor. Most nail guns are rated for 90 to 120 psi. Set your regulator to hold the hose pressure between 90 and 100 psi. Using higher pressure to set the nail will ruin your nailer. Use the depth adjustment on the gun to set how far the nail is driven.
Sep 23, 2010 | Nailers 3 12" Pneumatic Air Round Head...
GUN NOT SETTING NAILS
Hello jsc.... the depth that the nailer drives the nail is dependent upon two factors, the hardness of the material you are driving the nail into and the air pressure. Generally when you want the nail to go in more you adjust the air pressure to a higher setting, going 5 psi at a time until you are close to perfect and then fine tuning the air pressure.
Sometimes people find that the air compressor itself is inadequate for the job. in that case, the only choice is to move up to a higher psi compressor. Joe
Thanks for choosing Fixya!
Jul 04, 2010 | Hitachi 3 - 1/2" Full Roundhead Framing...
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
How many tools will operate at same time
I think you'll have to look at your specs on your nail guns and see what the demand is . Whether measured in cfpm or psi, your compressor will tell you the max output of each of those. Then you divide the maximum sustained output of the compressor,, lets say it is 60 psi. Let's say the guns require 10 psi, 60 divided by 10 is 6 = 6 nail guns. This is completely hypothetical as I have no idea what your nail guns require, only you know what kind of guns you have.If you need to run more guns than the compressor can push air for, you'll have to invest in another compressor, maybe even one larger to handle the guns running wide open consistent nailing. Nothing a drywaller hates more is than for all the cursed clip nails not being drove in all the way, lol, and that's what will happen with insufficient air supply.
Matt
Nov 18, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Air Compressor, low pressure
does the compressor keep running all the time but never gets above 40 or does it turn off at 40?
if it is turning off at 40 I would try using another gauge just to be sure it is 40psi, and if that is the case then you probably have a faulty pressure switch, if the compressor is constantly runnign but won't get past the 40psi then you may have a worn out compressor, check the oil for either a low level or if the oil is dirty, if it is you may just need to drain and refill but if that doesn't fix the issue then you will need to rebuild the compressor
Oct 11, 2008 | Air Tools & Compressors
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Ridgid Compressor With Toolbox On Top Logo
323 people viewed this question
Top Ridgid Air Tools & Compressors Experts
Joe Garcia
Joe Garcia
john h
John Trevino
Are you a Ridgid Air Tool and Compressor Expert? Answer questions, earn points and help others
