Question about Kodak Digital Science 4500D Path-Through Scanner
4500D is humming loudly from the left side as you look at it
This is a new noise from the Kodak 4500D have not heard this before and concerned as to why this nooise started and what I might need to do to resolve it
  • 31 Answers
Mains Transformer inside the scanner is vibrating.
Posted on Jul 07, 2009
Loud Humming/Wheel Bearings?
When you turn and hear a noise it is usually a CV Joint that is going bad. Humming can be a lot of things. Tires wheel bearings, rear end differential etc.
May 05, 2017 | 2002 Ford Explorer
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
Mar 27, 2012 | GE SpaceMaker Microwave Ovens
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
Have a strange humming noise that can be heard
Hi:
Often "humming" noises like what you are experiencing are caused by a failing bearing somewhere. Some usual suspects are wheel bearings, alternator bearings, and sometimes even your waterpump, but usually it starts leaking too. To start narrowing down what it is, have someone ride with you to see if the noise is coming from left side or right side, or engine area, then see if it happens when the car is not moving, or just when the drive wheels are pulling the car? This way , hopefully you can pin point the culprit!
Mar 26, 2010 | 1999 Volkswagen Golf
Yamaha pt300. was working fine. Now only makes loud humming noise which doesn't repsond to change in volume. Monitor display shows keys register as being played, but no sound can be heard except loud...
Likely the power adapter has failed if it uses one. Try a new one first.
If half the rectifier blows out, a very impure DC voltage is applied which will be heard in the audio output.
Sep 27, 2009 | Dean Dimeblade Tribute Electric Guitar
Loud humming after turning on.
I have sort of the same problem...there was a loud snap(kind of electical spark like) then the unit started humming loudly which changes sound as you move the unit around. The picture remains clear and the fan is quiet in shut down mode...still the wheel you think?
Sep 07, 2009 | Optoma MovieTime DV10 Multimedia Projector
Faint to loud humming noise while driving and turning...
Could be either a loose belt or you are low on power steering fluid,or the power steering pump could just be worn out.
Aug 20, 2009 | 2006 Chevrolet HHR
When warm, humming noise from front. engine or transmission
Did you replace the alternator with a new or used alternator? The transmission is controlled by the alternator on pacifica's. Check your caytilatic converter for the humming noise..
Dec 15, 2017 | 2004 Chrysler Pacifica
Kodak Digital Science 4500D Path-Through Scanner Logo
57 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
