Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
All of a sudden the pool filter pump (637) quit working
    Guru:
  • 351 Answers
The first things to check would be the breaker , there may be one near the pump and another at the main panel. Get back with your thoughts
Posted on May 12, 2010
Can we replace a SFS1000 pump with a SFS2000 pump on our pool?
can you use the bigger pump? yes. Should you? NO All the componants of your pool are based around the pools water capacity. The filter, pump, the plumbing, everything. Using an over-sized pump may circulate more water; but can lead to filter damage, or ineffective filtration. You don't need or really want, a hemi engine on your lawnmower.
Aug 19, 2014 | summer escapes 18ft x 48in Metal Frame...
My pool filter will not work and everything is plugged in and assembled properly. It has been working for weeks and suddenly stopped
might be the impeller on the pump has trash in it, this will restrict the pumps flow.. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 12, 2013 | Intex 10' x 30" Easy Set Pool
Hot day and 750 Magnum pool pump after vacuuming quit - left it off an hour or so and it works for about 1/2 hour and quits
CHECK FILTER, IT HAS TOO MUCH PRESSURE ON THE PUMP, CLEAN FILTER. OR REMOVE IT AND TRY..
Jul 21, 2011 | Pool & Spa
I have an intex above ground metal framed pool, the filter pump is model #637 Krystal Clear. I made the mistake fo running it 24/7 for several weeks and now it is leaking, some internal seal must be...
You will have to set winterize plugs in the pool to do this.
Remove the pump and motor from the plumbing. Then with the power off pull the wireing or simpley unplug the pump. Now all you need to do is take the whole thing to your local pool store and they can replace the seal and gaskets for you. Generally they will do this for the price of the parts or maybe a small fee. All pumps are different so this is the best way to get this done.
Aug 31, 2010 | Pool & Spa
I have a 15x48 intex metal frame pool with a 637 pump that uses A cartridges. I have cleaned out the filter and the skimmer and after hooking everything back up and bleeding air out of the lines I plugged...
if the system is consistently blowing air into the pool in large quantity, you most likely have a suction side leak that is allowing the pump to **** in air and return it back to the pool. try shutting the system off and inspect the suction side for any water leaks, that should lead you to any air leaks on the suction side. try turning the pump on and off a few times to catch any water spurting out of the suction side. Also, make sure the skimmer is now enough to not create a vortex and **** in air as well. Hope this helps.
Aug 24, 2010 | Intex 1 "a" Filter Cartridge Pool Pump...
Where can I get a new motor for an Intex pump model 637 or 12R
first off water should not be getting to the armature area. be carefull with how you are taking care of your pump.
secondly a 1500 gallon pump is very weak I would advise at least 2500 or even the intex 4000
the most important part of pool maintenance is circulation.
if you have time check into electric motor rebuilding in your area
but sometimes that is more expensive than buying new
also if you have a valid receipt and the pump is less than 90 days old call intex and they will send out a new one within 24 hours
good luck
Jul 26, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Which filters made by who is right for this model Krystal Clear 637
any b cartridge will do.
In fact off brands of the same filter hold up longer than intex brand.
This is my 3rd season with the same cartridge. Just blast it with your garden hose on high presure and you should be good to go unless you get a tear in it
hold cartridge and spray outside from top to bottom all the way around.
now turn it over and do it again.
you should do this at least twice a week and you will be good to go
Jul 14, 2009 | Intex Krystal Clear Model 635 Pool Filter...
The jets quit working when I prime and attach the vaccum hose
you could have a leak in the vac hose or a shaft seal on the pump, if there is a wet spot under your pump there is a good chance the shaft seal is BAD.... some pumps are so strong you can starve the PUMP for water, the trick is to set your valve more towards the main drain./ hope this helps.. i'm your local pool pump motor repair guy
Jun 20, 2009 | AO Smith 2 hp Swimming Pool - Jet / Well...
We have the same problem
Year after year I tell people to run their pumps for 15 seconds twice a month during the winter as the snow rusts the rotor to the stator and the pumps need service in the spring unless the power is not shut off right away the start windings will burn and the motor is breakfast toast
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
533 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
