Question about Dynex 4-Port 10 Mbps Ethernet Hub
Cant get other computer to work with the hub, its says a network cable is unplugged even though it works fine when plugged driectly into the modem. the other computer in the hub also works fine
  • 74 Answers
Please attached Lan cable in Your System lan card and another hub side then after its worked
Posted on May 11, 2010
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
Dell powerconnect 2016 seems to have stopped working
most likly a failed power supply on the switch
look at the front of the switch look for leds,.......
if you see nothing and the power cable is plugged into a hot outlet than
go down to your neerest comp store and buy a new one
Apr 26, 2010 | Dell PowerConnect 2016 (pct2016)...
I re-imaged the unit & it says the network card is working properly in device mgr. But it wont go online when i connect a cable. It stays on "Network Cable Unplugged". The LED on the connection on the...
1. Try different cable if possible.
2. Check the network port of the laptop. Make sure the pins are in tact and there is no dust/dirt or anything blocking the port.
3. Verify the other end as well. Check the hub/modem/switch or whatever you are plugging into. Make sure it's securely plugged in.
4. If plugging into a router, make sure you aren't plugged into the Uplink or Modem port. If it's a simple 4 port hub, avoid plugging into the uplink port as well.
5. If you have a cable modem that plugs into a router then into your computer, test by powering everything down. Plug the laptop directly into modem's ethernet port. Turn power on to modem. Turn power on to laptop. Check your network light and test internet. If it works there's something wrong with router. If it doesn't, look to the cable for issues.
6. Lastly, if none of those steps worked, remove the ethernet driver and reboot laptop. Let Windows detect the ethernet card, then re-install the driver choosing to overwrite the existing. Know that Windows will tell you you're device is ok just because a driver loaded successfully. It doesn't always know if the driver is the correct one.
Sep 29, 2009 | HP Pavilion N5415 Notebook
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
Message tells me to plug cable into local area connection. Nothing is unplugged but cannot get internet.
try resetting (turning off and turning on after 3 min) your modem or router or hub (whichever you're using). Then right click the little icon in the task bar that represents your network connection and select 'Repair'
May 10, 2009 | HP W2007 Desktop Monitor
How to hook up the Ethernet 5port Workgroup Hub Model No. ew5HUB
To start with please make sure it says router on it as the title says "Networking Hub". These are two different devices. If not return the Hub and purchase a Linksys Router then follow instructions below.
Assuming you have a router:
Before you begin unplug the power from the Cable or DSL Modem before you start as they will have to be powered on in a particular order I will discuss later.
Your cable or DSL modem will have a cable coming out of it that looks similar to a phone line except a little larger. The cable will say CAT5 or CAT6 or Ethernet on it.
On your Linksys Router there will be a ports/jack that you can plug the Cable into from your Cable/DSL Modem. You want to look for one labled "WAN" or "Internet". Plug it in then plug in the power to your Cable or DSL Modem. When the "Ready" light is on the modem, plug in the power cable to your router.
The next step is hooking it up to your computer. There will be anywhere from 1 to 8 more ports available on your Router that is number 1,2,3,4, etc. Plug another Ethernet Cable into any one of those ports. With the other end plug it into your PC or Laptop, there is only one port/jack on your computer that this plug will fit in. Power up your PC and voila, you should be on the Internet.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 28, 2008 | Linksys Instant Networking Hub
I have a cable modem. from the cable modem I go to a 5 port hub
That is because most cabel internet providers only gives you one public IP. Please go to a Best Buy, Office Depot, Staples, Walmart, or Targer, and ask for a LinkSys Router. The router will do NAT (Network Address Translation) that will allow more than one PC share the single public IP. This will solve your problem and will cost an estimated $30.00. The router is simple to hook up, just plug the cabel from your modem into the Internet/WAN port on the router. And the two computers into any of the other ports. Be sure to unplug both cable modem and router then plug up the cable modem first, once the ready light is on, plug up the router.
Adam
Nov 15, 2008 | Stratitec 5-Port 10BaseT Ethernet Hub...
Broad band hub
donn't connect the cable driect you use the 5port or 8port swicth then take a cble to modem to that swicth then how many computer you have to connect you can
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Wrt54g V8 Suddenly stopped working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | Linksys Wireless-G WRT54G Router
Dynex 4-Port 10 Mbps Ethernet Hub Logo
232 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
