Question about PLUS Vision Corp. U4-237 Multimedia Projector
Projector lamp reset required without remote control
I have a Plus UP-800 projector but not the remote control. I cannot reset the lamp usage as the red light blinks and the projector refuses to start.
Help!
SOURCE: replace lamp warning light goes on after raplacing it with the new lamp
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Posted on Aug 26, 2008
SOURCE: Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Posted on Dec 28, 2008
projdoc
  • 2237 Answers
SOURCE: Projector plus u4-237 gets on but it making continous noise
if it's a rough motor noise, the colorwheel may need replacing. while you're in there, clean it out with canned air.
Posted on Aug 19, 2009
projdoc
  • 2237 Answers
SOURCE: Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Posted on Mar 09, 2010
Testimonial: "Of all the comments on lamps failing to power up, only this answer fits my circumstances. I eliminated other "solutions" posted on FixYa. Thanks!"
  • 231 Answers
SOURCE: what does the lit red status light represent on a
http://www.mwave.com/mwave/SKUSearch_v3.asp?px=GA&scriteria=BP00182&BrandName=Plus&ModelName=U5-232 you need new lamp here is the cheapest 249.00
Posted on Apr 13, 2010
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Reset lamp time
The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the usage time of the lamp. Pressing the RESET button on the remote control or the ? button of the projector displays a dialog. To reset the lamp time, select the RESET using the ? button. RESET ? CANCEL • Please reset the lamp time only when you have replaced the lamp, for a suitable indication about the lamp.
May 13, 2015 | Hitachi CP-X505 Projector
Need to reset lamp usage time without the remote on NEC VT490
Hello
Press the MENU button on the projector's control panel to display menu options.Press UP/DOWN button to reach the RESET option window. There you can see Clear Lamp Hours and Clear Filter Hours option. Select the Clear Lamp Hour option and press enter. That is all. OK.
Oct 22, 2011 | NEC VT490 LCD Projector
How do I reset the Lamp timer o an NEC MT1050 projector... Without the hand held remote control?
On some Projectors that I used to service, Holding the power button whilst plugging into power did a lamp timer reset. ( Of course check the lamp is fully seated and the lamp door is closed
Feb 24, 2011 | NEC MT850, MT1050, MT1055, MT1056...
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Plus UP-1100 Lamp Hours Rest Procedure needed. The lamp is replaced but no menu option for resetting hours and Google provides no answer.
To reset the lamp timer on the Plus UP-1100, turn on the projector, press the menu key, navigate to the power menu, go to the lamp timer, then press and hold the "power on" button on the remote control for 20 seconds - you will see the timer reset to 0000.
Aug 05, 2009 | Office Equipment & Supplies
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Reset the bulb
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
Jan 12, 2008 | LG RD-JT91 Multimedia Projector
How to reset the lamp of NEC MT1050NL projector without the remote
You can do this via the buttons on the case...just navigate via the menu and find the menu for lamp resetting. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Oct 14, 2007 | Sharp Projector lamp Projector Lamp
PLUS Vision Corp. U4-237 Multimedia Projector Logo
181 people viewed this question
Top PLUS Vision Corp. Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a PLUS Vision Corp. Office Equipment and Supply Expert? Answer questions, earn points and help others
