USB devices not seen
Thanks for the very fast response. The usb controller list reads as follows. I am reluctant to delete all of these without making sure first. None of them are in bold.
USB Controllers
Standard enhanced PCI to USB controller
Standard openHCD USB Host controller
Unknown Device (6 of these)
USB Root Hub (3 of these)
Thanks
    Genius:
  • 3,587 Answers
I'm looking for those with question marks or exclamation points...
Posted on Mar 28, 2008
One of the USB devices attached to this computer has malfuntioned...
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 12, 2011 | Magicard Avalon Card Printer
It says my usb thing has malfunctioned???? help
Thanks, Joe
Feb 22, 2011 | Microsoft Wireless Laser Mouse 5000
I have purchased a Steel Series 3GC usb gaming controller, and every time I connect it my computer will not recognize the device. I have downloaded and installed the driver that they have listed on their...
Well, this is puzzling because all the drivers on the Steel Series 3GC site are for Windows 7 or above. The site doesn't even list the model you just purchased nor the 3.7 version of driver (which appears to be available from Softpedia rather than Steel.) 3.7 purportedly works for XP but I have seen advice suggesting that no devices other than keyboard and mouse ought to be connected to the USB ports during its installation. Uninstall the driver, reboot, install the driver again without the device being connected. I would even reboot it then, before connecting the controller. Perhaps subsequent connection of the controller will be recognized. Go into Device Manager and see if it is then recognized in the USB listings. If there is no exclamation point there beside the driver, you may have gotten lucky.
Jun 01, 2017 | Computers & Internet
How can i fix my usb mass storage that my windows xp sp2 does't recognize. It reads, ''usb device not recognize.'' pls. help me... it is urgent...
Follow the procedure listed below to correct your registry:
1. Open Start >> Run, and type "regedit" (without double quotes), and click OK.
2. Locate UpperFilters registry value. it resides in the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E980-E325-11CE-BFC1-08002BE10318}
3. Click on Edit menu, and select Delete and click OK.
Note: If you receive an error when you try to delete the registry subkey, you may not have correct permissions to edit the subkey.
4. Locate LowerFilters registry value. It resides in the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E967-E325-11CE-BFC1-08002BE10318}
5. Click on Edit menu, and select Delete and click OK.
6. Exit Registry Editor and restart your system.
We hope this helps to fix the trouble.
Jan 09, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
'USB device not recognised
Hi Peter,
Try this solution. Just follow this step to uninstall and reinstall the USB drivers. I am assuming that you have a Windows OS.
1. click START
2. right click My Computer (an icon of this can also be seen on the desktop)
3. left click Manage
4. Computer Management will appear
5. look for Device Manager and click it
6. on the right panel, you will see Universal Serial Bus controllers
7. expand that by click the plus (+) sign next to that
8. delete everything under that by highlighting each one of it, then on the keyboard, just press delete
9. once finish with everything, just reboot the computer
Let me know if this works.
Jon
Oct 10, 2009 | Fujitsu Siemens Computers & Internet
USB suddenly malfunctioning on Dell TOwer
It does sound like your ports on the front might be bad. They usually connect to a seperate port on the motherboard than the rear ones, and I have seen devices short out the front ports, such as a USB music player.
You can remove the ports on the device manager, and they should come back ok, without worry. However, I doubt that is going to help the front ones. I think you have a hardware problem.
If that is the case, the easiest solution is to get a USB hub, and run a USB cable from the rear, to the front of the computer.
Mar 28, 2009 | Dell OptiPlex GX260 PC Desktop
Uninstall usr usb maxg driver
These instructions assume Windows XP. Correct me if I'm wrong.
Insert the adapter.
Navigate to Control Panel (classic view) > Administrative Tools > Computer Management
In the Computer Management window, select "Device Manager" in the left-hand menu.
Click the + sign in the "Network Adapters" field.
If the adapter shows underneath "network adapters", follow the instructions below to completely remove it's drivers.
It's a little involved...:
1.)Go to the device in the device manager>Right-click>Properties.....
2.)Click "Driver Details" and make note of all the files listed. Once the device is gone, you need to delete those files......
Secondly, you need to find the .inf responsible for it's installation.....
3.)Go to the Details Tab, and highlight the long string....Theres a drop down at the top, it should be on "Device Instance ID" (XP, might be a tad off on the verbage)
4.)Press control+C to copy it....
Looks something like the following....
USB\VID_03F0&PID_4F11&REV_0100&MI_00
5.)Navigate to C:\WINDOWS\inf in Windows Explorer (My Computer)
6.)Press F3 and copy that string to the "A word or phrase...". Make sure, under "More Advanced Options", "Search system folders", Search hidden...", and "Search subfolders" are all checked.
7.)Perform the search. If nothing is found, take off a chunk at the end, 1 at a time, going up to the &...
1st... USB\VID_03F0&PID_4F11&REV_0100&MI_00
2nd... USB\VID_03F0&PID_4F11&REV_0100
3rd... USB\VID_03F0&PID_4F11
...etc, uintil you get a hit, with a "Driverfilename.INF". Rename that .inf file to .OLD.
7.)Now go back to the earlier part where you found all the listed drivers in the Driver Details tab, and rename them all to .something, or remove them to a safe directory outside the systemroot.....
8.)Reinstall your Drivers for the device, and plug it back in and you should have new drivers...
Mar 24, 2009 | U.S. Robotics MAXg USR5421 802.11g/b...
All my usb ports are not working when i connect any pen drives or external hard disk or bluetooth deice my computer doesn't read them what should i do?
Plese make sure that your USB port is enabled in BIOS Mode,
if it is enabled make this steps....
Download USB Driver files....
usbehci.sys
usbport.sys
usbhub.sys
usbui.dll
usbccgp.sys
usbohci.sys
Feb 20, 2009 | Microsoft Windows XP Professional With...
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
