Question about HP Scanjet 4370
Hp scanjet will not copy to print
When attempting to copy anything I get the message "must have a printer setup to do a copy. Go to control panel and install a printer [1211]." I have two working printers installed already. Scanning a document to the printer works but the printing time is terribly slow. I have reset the scanner by unpluging the power for 60 seconds, reinstalled the software.
I posted this info on another thread to answer "reply if you have the same problem" but the posted result indicates I have a solution to the problem. NOT.
  • nekopijuoja Apr 18, 2008
  • Scambo Mar 06, 2009
    I have the same problem that has been described about the copy not working. However I have problems with the suggested solution. First I cannot click start and find my Printer. I have to go to the control panel to locate the printer. Secondly when I right click the default printer on the general tab I get no response., therefore no copy button to click My journey ends there. Are there some steps missing in the solution?
  • 47 Answers
FROM HP, searched and found after three or four weeks of unresolved solutions .. and that's fixed the problem !!
Solution Follow the steps below:
  1. Click Start , then Printers and Faxes .
  2. Right-click the system default printer and click Properties .
  3. On the General tab, right-click the default printer and click Copy .
  4. Click Cancel to exit.
  5. Click Start and then click Run .
  6. In the Run dialog box, type regedit and click OK . WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Hewlett-Packard cannot guarantee that problems resulting from the incorrect use of the Registry Editor can be solved. Use Registry Editor at your own risk. It is strongly recommended that you make a backup copy of the Registry before you edit it. For information about how to edit the Registry, view the "Changing Keys And Values" help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" help topics in Regedit32.exe.
  7. In the Registry Editor window, click Edit , then click Find... , and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy .
  8. Double-click Printer in the right pane.
  9. In the Edit String window, paste the printer name as it appears in the Registry under Value data (for example, hp photosmart 8400 series) .
  10. Click OK and close the Registry Editor.
  11. Press Copy on the scanner. The default printer connected to the system should normally print the scanned document.
Cause This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy function in the Current User section of the Registry.
Posted on Oct 12, 2008
SOURCE:
No printing, printer says ready, will test print from menu button
Go to my computer, click on control panel, click on printer/fax and see what is set for default. What ever printer icon that says ready, right click and set as default.
Mar 11, 2010 | HP LaserJet 4 plus Printer
My printer won't print anything from my computer
Is this a USB communication? Try deleting the printer, pull the USB connector, and go through the entire install procedure again.
Jul 14, 2009 | HP LaserJet 1320NW Printer
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
HP PSC 500 print cartridge all in one
remove both cartiges and turn turn it off make sure you put the flaps down before you turn it off. then turn it back on and insert both back in there gentle and pull down the latches slowly and carfully as to not break it and then alighn cartiges with the front panel messages touch select-resume to align them until it says copy in the front panel messages that should get it working again.
Jan 08, 2009 | HP PSC 500 All-In-One Printer
HP Photosmart D7460 Error Message
Remove the HP Smartweb printing software.
1. In the Start menu select All Programs > HP Smart Web Printing > Uninstall HP Smart Web Printing.
2. Follow the onscreen prompts.
You can also open the 'Control Panel' from the 'Start menu' and open 'Add or Remove' Programs. Select 'HP Smart Web Printing' in the 'Add or Remove' Programs window, and then click 'Remove'.
If the changes you make in the Page Setup dialog of Internet Explorer are not reflected in the Page Setup dialog of the Print Clips window and vice versa ?
This is a known problem, and not unique to HP Smart Web Printing. When printing from the Internet Explorer File menu, select File > Page Setup and make your settings there. When printing from the Print Clips window, click the Page Setup button and make your settings there.
Now install the smart web printing software from the weblink provided below:
After removing the smart web printing software, please visit the weblink and download the HP Smart Web Printing 4.05 software from the webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=dj-56929-5&cc=us&lc=en&dlc=en
Just copy and paste the entire link(without spaces) in the web browser and press enter.
For more information on how to install the software visit the below weblink which leads to a webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c00793678
After performing the steps mentioned above, check the functionality.
Oct 27, 2008 | HP Photosmart D7460 Printer
Direct Printing
Mar 27, 2008 | HP Scanjet 4370
Check Printer Cartridge message and a large E in the copies section
Well the manual request I can do - go to the link and there it will be in all it's pdf glory.
http://h10032.www1.hp.com/ctg/Manual/c00141855.pdf
Jan 30, 2008 | HP ScanJet 2400 Flatbed Scanner
Hp printer won't copy
1. turn off / on the printer
2. press setup hold down and press options
3. press start color copy
worked for me on psc 2175
Sue
Jan 17, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP Scanjet 4370 Logo
651 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
