Question about HP Photosmart C7280 Printer
Experiencing a problem with an HP Photosmart C7280 All-in-one printer, after the yellow ink cartridge was replaced a 'change the cartridge' screen comes up when trying to print, even though the printer shows the new ink levels are OK with the newly installed yellow cartridge. Just installed the current updates for the HP C7280 and problem still persists. Any thoughts?
  • 2bros May 12, 2010
    I found a fix for my HP C7280 printer and wanted to relay this to anyone else experiencing this same problem. After downloading a diagnostic utilty from HP on the site out-of-warranty.com, my problem is gone and I am able to print in color once more! There seems to be a lot of HP printer problems surrounding the yellow ink cartridge and this out-of-warranty.com site seems to have other ideas to try for this specific problem. Good luck HP users!
  • 30 Answers
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
You may also try this: Press and hold the '*' key on the key pad, then press the '#' key and release them both. Then enter '123' to enter maintenance mode. Then press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then press OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then power it off and back on.
Posted on Jul 26, 2010
Photosmart c7280 ink threshold exceeded
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
Dec 08, 2013 | HP Photosmart C7280 Printer
The pink and magenta cartridges won't print. We have replaced them again thinking the cartridges were faulty, but still we just get yellow print. HP Photosmart C7280 All-in_One
Sounds like you need to run a printhead cleaning cycle. Dried inks can block nozzles - if they're blocked no amount of cartridge changing will make them work.
www.inksave.co.uk
Feb 11, 2011 | HP Photosmart C7180 All-In-One InkJet...
HP02 Ink (Expired)
I HP made cars they wouldn't start until you change your dirty motor oil.
May 07, 2010 | HP Photosmart C7280 Printer
Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
Error 0xc18a0105 - ink faillure for HP c7280-help
Go to our web site at : www.ccl-la.com/ and click on the printer service section. We have a walk thru that will get you back going. The problem you have is caused by air in the ink feed tubes and the repair guide will show you how to do a feed tube purge.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 23, 2009 | HP Photosmart C7280 Printer
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
My HP Photosmart C7280 does not recognise refilled cartridge.
Yes that is because when you get a cartridge refilled then what may have happened is when you gave a print command some of the ink may have splattered onto the ink spraying sensors(usually happens with refilled cartridges on any printer).Its because of the heat generated with which the ink nozzles cannot handle as the ink that is sprayed from refilled cartridges is a little more than regular original ink cartridges.Dip a cotton swab in water wipe the copper contacts on the cartridge.Then wipe around the place where the cartridges sit and also wipe the carriage rod which is inside the printer (metal rod)along which ur spraying mechanism(carriage) moves. If this does not resolve your issue call in to hp at 1800-474-6836 and you can purchase original cartridges that are just for 11 dollars each.........or you can purchase a combination pack which will be cheaper
Jun 15, 2009 | HP Photosmart C7280 Laser Printer
Installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7280 Printer Logo
296 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
