Question about Brother HL 2140 Laser Printer
HL-2140 Clean Corona wire Message won't go away.
  • 240 Answers
If you are getting "clean corona wire" on your PC and the toner light on the machine is solid, you need to change your toner cartridge.
This is a bug in the brother software.
Thanks,
Pat
Posted on May 12, 2010
  • trevorjmorri
    trevorjmorri Mar 05, 2013
    I changed the toner cartridge for a brand new one (Brother brand). No joy - still getting the "clean corona wire" message.
My printer HP ( HL-2140 laser ) print out a black sheet?
This will be the Corona Wire on the drum has broken. Replace the Corona Wire if you are technically minded or replace the drum unit if you are not.
Jan 10, 2015 | Brother HL 2140 Laser Printer
How do i clean the corona wire for my hl-2140 printer?
Well the best solution for the corona wire is to change it. It is the best and safest solution.
If you need further details and assistance please leave a comment. Cheers
Aug 25, 2010 | Brother HL 2140 Laser Printer
you have to take out the drum and on top of the drum unit, there is a blue color plastic which can be slide from left to right... just slide a few times from left to right...that will clean the corona wire .
Jun 15, 2010 | Brother HL 2140 Laser Printer
Get a clean the corona wire. Have removed the
Try using canned air to blow out that corona area, and then a Q-tip moist with alcohol to gently wipe the corona wire, if all that fails you will need a new drum.
Also press the go button 3 times so you get a printout and check that you are getting a clean the drum error or something else.
Dec 18, 2009 | Brother HL 2140 Laser Printer
Get error light when trying to print labels - HL 2140
The driver should pop up a error message. Possibly is due to clean corona wire. Slide the blue lever several times across (at the drum unit).
Dec 10, 2009 | Brother HL 2140 Laser Printer
Printer won't print error message corona wire needs cleaning
When you experience a persistent problem like this right at the beginning - listen to your own good advice. Take it back to the store and exchange it for a new one.
Jul 30, 2009 | Brother HL 2140 Laser Printer
Brother HL-2140 Corona Clean Error Won't Go Away!!!
The error message is misleading. The printer wants a new toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000026/faq002526_000.html?reg=us&c=us&lang=en&prod=hl2140_all
Jun 30, 2009 | Brother HL 2140 Laser Printer
CORONA WIRE CLEANING
SWARNAVA has the most common wrong answer to this problem...
I am waiting for a firmware update to fix this issue. The only solution is repeatedly removing the drum/toner, moving the green cleaner back and forth, putting it all back together loosely, putting it in the printer loosely, and closing the door gently. Hold down the blue button until all the lights glow, then release. If you're lucky you only have to repeat this process a dozen times until you trick the sensor into not giving false readings.
Jan 20, 2009 | Brother HL 2140 Laser Printer
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
843 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
