Question about Refrigerators
How to disconnect water filter
Trying to replace external GXRTQR (GE Smart Water) filter. How do I disconnect the filter? Press on grey tabs? or pull on grey tabs? I don't really want to break these by forcing.
  • Refrigerators Master
  • 2,651 Answers
Were talkin about the inline water filter with 2 connections on either side of cylindrical filter???pushing in on the tabs should make the "quick release". don worry about breakin they come with the new replacement filter, as do the instructions for installing
Posted on Mar 29, 2008
Ge smart water heater model SE80T1ZTAH
Try this:
1. Turn off the power to the water heater.
2. Press the reset button.
3. Replace the insulation and jacket access panel(s) before turning on the power to the water heater.
Please let us know if this works!
Nov 04, 2013 | Water Heaters
I am trying to install a new water filter and water wont stop gushing
There is an oring ( black washer that looks like a black band ) that is not in place . You must have that to keep it from leaking.
Mar 01, 2013 | GE Smartwater Refrigerator Ice Maker...
I have a Leisure HJA6100. The ice dispenser has stopped working.
Yes indeed... but much depends on how hard your water is and the condition of your pipes feeding to your ice dispenser... pipe rust and particles = clogged filters.
I tried to find a schematic diagram to see if there is a water pressure sensor switch somewhere, but no luck... sorry... it was a thought.
But I discovered your filters are quite expensive and none are to be found on eBay and that's highly unusual! One filter will cost you about $60 ~ no thank you.
I would do my best to remove that filter MOUNT and install a "inline" filter that will do the same job and for a LOT less. Add few PVC adapters, maybe a short length of copper line and 2 rubber sleeves and you are back in business... at least filter-wise.
Extend the lines and you can place that filter almost anywhere. The second link shows your FILTER MOUNT... and looking at this photo it looks like it can be a fairly easy job.
You do not want to keep hunting and paying $60 and more for "exotic" water filters so here is a decent GE GXRTQR Inline Filter, 3-Pack for $22.88 including shipping.
FILTER HEAD (to gather a few adapters)
Leisure HJA6100 Water Filter Head
eBay 3 Pack FILTERS
GXRTQR Inline Filter 3 Pack eBay
Leisure HJA6100 Fridge Freezer Parts Replacement for GE
Dec 02, 2017 | Refrigerators
Gsh25jfxj cc
Sounds like it needs cleaning, descaling and a new filter.
May 16, 2017 | GE GSS25JFM Side by Side Refrigerator
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 26, 2011 | GE Refrigerators
Water will not flow out of dispenser
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Sep 07, 2009 | GE Refrigerators
I have a water softner in my house do I need the smart water filter on the refrigerator GE model PSS26NGSA GE PROFILE. I use the filter bypass plug but there is no water running thru the dispensor. Do I...
If your using the correct bypass plug which came with the refrigerator , the water dispensor should still work . Make sure the plug is very snuggly , tight in place .
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water won't flow from GE Smart Water under-sink RO water filter
Disconnect the water pressure tank making sure the end the line hooks up to is open. The tank should be relatively light, and if you shake it you should not hear any water. If you hear water in it, or it feels heavy, that means the bladder inside the tank has failed. Replace the tank with a new one, and set the pressure on the bicycle type valve at 8 PSI before you connect the tank up to the water line.
Dec 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
In operative water dispenser.
I have GE side by side refrigerator - 2004 model GSH25SGRB SS. From the blog I found out the problem is with frozen water line. If I keep the door water would dispense ( thawing). Or if you disconnect at the bottom ( take the grill out and disconnect) the water would dispense.
I placed a call to GE. The service person came. He said GE could fix with a 3 watt heater. He opened the panel. Pasted a heater. It came in a Y shape form. He connected that to the internal wiring. After some time the water started working.
Part $40. Labor for 15 min work = $210. Total = $250.
This is really should be a recall case. No part broken. They had to design a heater to solve this problem. What a rediculus thing is this. I am trying to call GE and ask to refund.
What a cheat GE!!. F them.
Feb 11, 2008 | Refrigerators
Refrigerators Logo
762 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
