Question about Kodak Carousel 4600 Slide Projector
Tray will not advance
The carosel does not turn when the forward or backward buttons are deopressed. However when the large rectangular button is depressed the trat can be turned by hand ans released
    President:
  • Kodak Master
  • 412 Answers
The problem you describe is most likely a broken spring on the lever that moves the tray forward or reverse. The repair requires dis-assembly of the projector and the slide change mechanism and adjustment after re-assembly. I recommend you contact a factory trained repair dealer to make the repair.
Posted on Nov 22, 2010
Can I advance my slide tray manually?
A Kodak Carousel 600 has no Forward/Reverse buttons for tray movement. The only way to advance the tray with the slide change mechanism is by LIGHTLY depressing the SELECT bar. To manually advance the tray, push and hold the SELECT bar down fully.While holding the SELECT bar, you should be able to rotate the tray by hand. Good Luck!! Jim
Aug 08, 2013 | Kodak Carousel 600 Slide Projector
How to clear paper jam
How you clean the paper jam depends on where it is located and how large the piece is. If you turn off the printer and turn it back on, then press the "ok" button when it says that there is a paper jam - it will rotate the paper inside forward all the way and then retract backwards. Watch the front of the machine and try to grab the paper when the rollers bring it forward. To get it using this method you have to be really quick. If you dont catch it before it goes backwards then press the ok button and try again.
If you are unable to see the piece of paper when the rollers rotate forward, then unplug the machine from the power source and press and hold the power button for 45 to 60 seconds. Then turn the machine around so the the back is facing you.
There should be an unlockable paper access tray on the back of the printer that has two plastic hinges to depress while pulling outward to remove it. Remove the hatch and see if you can find the paper that is stuck in this area. If so, grab it and remove it.
Jul 17, 2011 | Canon MG5250 Printer
860 slide projector does not move carosil forward or backward and does not respond to selecting slides, but manual on projector will actuate slides but will not move carosel forward or backward. thanks
there is a small rubber link inside the projector that controls the advance this part fails in time and would cause this problem. the part is not hard to recreate but is difficult to replace.
Jan 16, 2011 | Office Equipment & Supplies
2 days ago my Kodak Carousel 760H projector started going backward or forward at will, inspite of which button was pushed. Now it will not go forward or backward with either the handheld or the side...
This is not an easy repair. It would probably be more cost-effective (if you will NEVER use the projector again) to rent one for the remainder of your project.
The problem you are describing is most likely a broken "link". The "link" connects the cycle solenoid to the slide change mechanism. Over time, this plastic "link" gets hard & brittle, and cracks, giving the failure you describe. It is a significant tear-down of the projector by a trained technician.
Nov 06, 2010 | Kodak Office Equipment & Supplies
Just bought a kodak 650H slide projector and i put a tray with slides on the projector but it doesn't lock in or advance.
Chances are the projector you bought needs a slide change solenoid link or at the very least, an adjustment to the timing of the slide changing mechanism.
Oct 26, 2010 | Kodak Office Equipment & Supplies
Can you tell me how to decode a grunkel dvd player to all regions?
Model 20-NT
1. Using the remote control, key in the following: Setup, Stop, Skip Backwards, Skip Forwards.
2. You should then be able to change region and remove MacroVision.
Turn on the DVD player without DVD inserted. Then, using the remote control, press this buttons: Setup, Stop, Skip Backwards, Skip Forwards.
Model 22NG
Turn on your player
Open the tray
Press 8 4 2 1 on the remote control --> "Region 2" appears on the TV screen
Press SELECT until 9 for region free & MacroVision free
Model 32S
Press Setup
press Volume +
Press Volume -
Press the right arrow until the screen on the player reads 255
Press setup to exit and all done
Nov 17, 2009 | Televison & Video
Ekatagraphic slide projector that won't advance the carosel forward or backward. it will pop a slide up and down. it sounds jammed it humms when buttons are depressed any ideas?
The most common causefor the failure of the slide tray to advance or reverse is the breakageof this small Link (part # 217769). It fits on the end of the solenoid actuator arm and is held in place by a Rivet (part # 159943). Thereplacement of this part does not take a rocket scientist, however, amoderate mechnical aptitude skill is required.
This Set contains 1 Link and 1 Rivet. If your projector Does NOT have a focus motor in it, then this is the kit for you. If your projector does have a focus motor, please order "KODAK-KIT" From: https://www.micro-tools.com/store/item_detail.aspx?ItemCode=LINK
Apr 24, 2009 | Office Equipment & Supplies
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Kodak Carousel 4600 Slide Projector Logo
362 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
