Question about Schumacher & Fast Charge Starter Charger
NEED A NEW PC CHARGING BOARD 2999000981 - Schumacher & Fast Charge Starter Charger
My laptop battery does not charge
You will have to replace the battery unless the charging board is bad and not charging.Most likely a new battery would work great.Thanks...Lee
Nov 07, 2011 | Computers & Internet
My nokia e63 does not charge. I buy new battery but same problem were encountered. What will I do? tnx n good day.
Does work all ok and dont charge? Maybe its broken dc jack connector, or the charger or a fuse inside. Try with usb on pc some nokia can charge from pc.
Jun 30, 2011 | Nokia E63 Cell Phone
Hi, my samsung laptop has an intermittent charging problem i really need help with please. i changed the inside jack lead because there was a break in the wire, the new jack lead gives me power all...
this is a common problem with laptops as you are using a new ac adapter helps a great deal the problem lies in the dc jack on the mother board not an easy task it needs replacing
Mar 15, 2011 | Computers & Internet
Charging ok bat power not coming.this mother board was no power & charging.whate can i do.
Try changing out the battery with a new one and see if it charges since the power supply is working because its charging. If a new battery doesn't work then the motherboard is bad and would need to be replaced.
Sep 22, 2010 | HP Pavilion dv6000z Notebook
My son has a HP DV6500 laptop and he was having trouble with it charging. I bought a new cord for it and a NEW battery and he was charging it and then it stopped charging and will not turn on. what is the...
Sounds like the charger board may be bad.This may prevent the laptop from getting current to get it started up.I'm not sure if the board is integrated into the motherboard.If it is the motherboard will have to be repaired or replaced.Alot of times the charger board is replaceable without soldering though.
Aug 09, 2010 | Computers & Internet
Laptop intermittently charges / works
Seems the power board is defective, you need to take this laptop to a service center to check for a new power board or if diy check ebay, you can find a good one there.
Jul 08, 2009 | HP 530 Notebook PC
Battery charging problem HP DB6000 series
They either didn't replace MB or didn't replace charging IC on MB. Needs to be done either.
Jan 04, 2009 | HP Pavilion dv6000z Notebook
Acer aspire 4920 charging mechanism failed
Most laptops, as in 99%, have one board and everything is on it. They don't really have a power supply since the AC adpater provides DC voltage already. There is just a voltage divider that take the incomming voltage and changes it to the various voltages the machine needs. The charging mechanism is also on the mainboard. I've very seldom seen a seperate power or charging board in a laptop. Unfortunately since you've already replaced the battery and the ac adapter and since the adapter is powering the laptop then there is definitely a problem with the charging circuitry on the mainboard. This isn't something one can repair unless you start changing micro components and ICs on the board which isn't recommended. Looks like a new mainboard or a new laptop is in your future if you want it to run off battery.
Another option is to get an external battery that mimics your ac adapter but that wouldn't give you a very long run time compared to the internal battery.
Don't forget to rate my solution in your premium thread as FixYa if you think I helped solve your problem. Thanks.
Aug 28, 2008 | Computers & Internet
Computer will not turn on, ck power supply it is ok, had computer ck'd at best buy they say I need a new mother board. I would like to find out how much it will cost for my pc.
I went to a local computer store and purchased a new mother board which is all I needed to begin with but no one was willing to tell me how to get one without a charging me for the information on how to purchase a mother board from your company. but thank you anyway.
Aug 11, 2008 | Gateway Computers & Internet
Schumacher & Fast Charge Starter Charger  Logo
95 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Lawrence Oravetz
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
