For a SANYO TV Power Board # DPS-242BP A S/N: A47W0747108528 REV:S2 F What exactly is the component on the board that is identified on the board as "Z800" ?
  • 10,594 Answers
Can you post an image of Z800 ?
This will help to identify the part.
Thanks.
Posted on May 11, 2010
  • 9 more comments
  • Walter Burien
    Walter Burien May 11, 2010
    The SANYO Model for the TV is DP42647
    I took the component off the
    board and the component was flat on both sides, circular with two contact wires coming straight out from the bottom, color yellow, and it had a brown sleeve inserted over it.
    On the sleeve I was able to make out all but one character that was burnt off.
    I replaced that with a (?) It could be a 1. My guess is it is: 110.0/5 with the letters before it being: HSXPO
    ?10.0/5
    The component exploded so it was hard to see the markings on the sleeve. The component itself was fried and had burst so the markings on it were not there to read. The height of the component circle was about a 1/3rd of an inch. Thickness about 1/10th of an inch.
    The internal parts that were shown due to the burst were two circular metal discs with a contact wire that went to the board coming from each.
    Walter
    Tel. (928) 445-3532
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Thank you for detailed info about Z800
    It is VDR (voltage dependent resistor) and installed on AC line, its job is to get shorted if AC supply exceeds and blow off fuse to protect power supply primary circuit that can be occurred due to over voltage AC supply.
    Below image shows its symbol in schematics.
    Its a protection device and you can replace it with similar vdr from any other tv power supply circuit.
    Hope this info will help you.
    Thanks.
  • Walter Burien
    OK, getting closer. The answer to the question would be:
    For me to order that component for replacement I need to know the exact specifications to replace this VDR. So for this board and this component when I place an order for it, what exactly am I going to request to get the same having the rating required for correct replacement?
    Thanks,
    Walter
  • Walter Burien
    PS: If you have the correct one can I buy it from you?
    If not, your recommendation of a company to order direct from?
    And when I get it does it mater what direction it is attached?
    Thanks,
    Walter
    Power supply board of DPS-242BP is not suppose to be repaired on component level hence no spare parts nor part numbers available.
    Please replace complete power supply board and it is available with Shop Jimmy for $83
    Thanks.
    Power supply board even work without VDR Z800, remove it from circuit board, put new fuse and plug it in wall socket.
    Power supply will work if no further part is damaged in primary section.
    Z800 is only protection device.
  • Walter Burien
    Already purchased a new board for $80
    Wanted to repair the old board as a backup.
    So, from what I have heard so far I can connect a 110V fuse to that circuit but 5A, 10A, 3A, ????
    Or replace with a VDR circuit of what rating????
    Walter
    PS: And the power board will NOT operate without that circuit.
    Fuse rating would be 250V 5A
    Replacement Varistor can be used and there are many available in Part Store.
    Varistor does not have polarity pins, can be put in circuit board freely.
  • Walter Burien
    And the "correct" Varistor part number for replacement of the Z800 component being that their are over 1000 different ones with different values listed?????
    Click this link to get nearest match varistor.
    Thanks.
Where is capacitor located on TV
There are several.
You should be identifying the four large components
- Power board
- Logic board
- Timing Control (TCON) board
- LED inverter driver board
99% the capacitors you are looking to identify for a power related issue on the power board.
capacitors look like
26155016-a3z50hdvc01hdf5dkelcuavu-4-0.png hope the video below helps you identify the defective capacitors
Fixing the Blown Capacitor in Samsung TV Yourself
Apr 07, 2016 | Televison & Video
Model dp46841 sanyo 47 inch tv won't power up
Likely a power board issue. Check that capacitors are OK in the power board, and if blown then replace with exact parts. This is a $10 fix, but if it does not work after than then cost go up like replacing the power board completely.
Oct 06, 2014 | Sanyo DP46841 46 LCD TV 1920x1080, 60 Hz,...
My 42 inch sanyo wont turn on, the power to the outlet works
Hello jboogie3945,
Welcome, and thanks for using FixYa!
To answer your questions: Since you have tested the outlet this set plugs in too, and it is ok, then we can turn our attentions to the Power Supply Board.
With confidence, we can say this board will need to be checked for a blown fuse or the entire board will need to be replaced. I have included the link below, so that you can see what the board looks like, and in the event you need/want to replace it.
Power Supply Board
http://www.ebay.com/itm/SANYO-DP26647-DPS-161AP-1-/360367778759?pt=LH_DefaultDomain_0&hash=item53e797ebc7
Have a great day!
Sep 12, 2011 | Sanyo Vizon LCD-15A2 Television
I own a sanyo "26
Tv now have it on green LED power on for good and tv flashes of pictures only for few min,than dies and have sound left only?Yes,take the tv aparts.U have all the tools and understanding basic electronic also can do basic soldering work too?Check the tv power supply board,that the board where the power a/c cord plug into it.Check the tv power supply board carefully for dead and dying components parts call capacitors.These dying and dead capacitors parts most likely all of the times,will bulges up or puffing up onto it tops.Changes all these dying and dead capacitors parts components,will solved this problems 70% of the times.If the tv power supply board it is good and no dying or dead capacitors component at all.Than the tv a long board that call the LCD inverter board it is dead.This LCD inverter long board are to helping the LCD screen panel to have a backlight to produced a picture.The tv long LCD inverter board have no parts for sale indivitually,al way have to buy a refurbish whole long LCD inverter board for the replacement.Also if you have no tools and soldering skills to fixed the power supply board by replacing capacitors component parts indivitually too.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a long LCD inverter board for the replacement.
May 28, 2011 | Sanyo DP26649 26 in. TV
I have aVizio VX42L HDTV10A. was watching a show when we heard a loud pop.Then all went dark. Would not turn back on. I took off the back cover and found the ceramic fuse was blown on the board # DPS-283AP...
This means you have a dead short, It is probably a Diode in the power supply area, but without testing board you don't know. If you know basic electronics, i would say check all diodes in power supply and look hard for something burnt and replace that also. Or just replace power board, check shopjimmy.com
Dec 08, 2010 | Vizio VX42L 42 in. LCD TV
Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2010 | Sanyo 42 in. LCD TV
No sound, i checked the speaker on off, mute, there is no sound
There are three separate video boards inside the tv. One is a digital cable tuner, one a digital input board (VGA, HDMI), and the other is the analog board. The analog board I believe contains the audio components of the tv, so if the sound has gone out yet video still works, that particular board may be at fault. It is available on ebay from several different sellers, the part number is 071-13182-00300. The power supply on my set went out as well too, and I think it fried a component somewhere on the audio board, but I haven't been able to identify which one exactly, was wondering if you've had any power issues, or have yourself already replaced the power supply on your tv....
Mar 17, 2010 | Protron PLTV-32 Television
DPS-210EP-2 power supply blew up
hi there the 8 pin ic in question is a Viper22a available from good electronic stores i got mine from
Cricklewood electronics for a couple of quid , also replace the capacitor c72 47uf
hope this helped
my board is DPS-210EP B REV 00
should be same
Jun 12, 2009 | Westinghouse LTV-32w3 HD Television
No power at all. No amber light or green light. Power cord check out fine?? Work great then 8 hours later went to watch TV. and nothing. Any help out there ??
I've been hearing alot about the main power supply board with this model. Mostly I hear that when the power button is pressed, the relay inside will click but with no other response from the TV. This tells me that either the relay contacts are no good or that there are some serious soldering problems on the board. That would explain why it will operate for a short time then quit unexpectedly. Thermal cycling might be stressing the already weak solder joints causing intermittent contact. Personally, I'd love to get my hands on one of these boards.
If it were me and I had nothing to lose, I'd pull the main PS board and touch up the relay section by resoldering (as I believe it is more likely to have bad solder joints then the bad relay contacts). If anyone tries this with positive results, please let me know and rate accordingly.
Dec 29, 2007 | Vizio L37 Television
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
