Question about Casio G''zOne Type S Cellular Phone
Shuts off on its own constanly
The phone is shutting off automatically and blinks on sometimes just for seconds; with a fully charged battery. This happens both in vibrate and ring modes.
  • Anonymous May 30, 2008
    My phone will turn off all sounds and reception for the phone. It will not register any calls or text messages. This has happened when sitting on the counter all by itself.
    I thought I was hitting the wrong button/key and or combination of keys.
    My problem was confirmed by Verizon customer service this last week.
    My phone has not been subject to water at all. It is used daily on the construction site for business phone hence the reason I got this phone in the first place.
  • Anonymous Sep 05, 2008
    My phone is Displaying fs_pm_ptable00843 when booting and refuses to boot What can I do???
Try opening both ports and allowing the internals to dry. I had the same problem and traced it back to water and/or moisture in the phone. The phone is water proof as long as the keys aren't pressed underwater, which in my case ruled out text messaging in the shower...
Hope this helps
Posted on Apr 14, 2008
SOURCE:
My Gateway laptop, NE56R1u, shuts down automatically when unplugged even though fully charged?
Dear Leslie,
I had the very same problem with a HP Pavillion DV4 laptop and the problem was inside the battery - one of its cells became defective and the charge did not last more than a few seconds - it also showed a 100% charged icon but the battery was depleted in seconds.
Before buying a brand new battery you could check with a friend that has a similar laptop if he/she can lend you his/her battery for a few minutes and check whether the laptop keeps on or not with that other battery. In the case it remains on, it is the battery for sure, and you will need to buy a replacement one. Check the link below, for one option.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
6cell Laptop Battery for Gateway NE56R41u NE56R42u NE56R43u Nv50A02U...
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
Black decker cordless drill ldx120 runs for a second and shuts off, battery fully charged and the led light comes on and is bright.
The brushes on the motor may be worn . The battery may have several bad cells in it. The led lite only needs 2 volts for full brightness.
Jan 17, 2014 | Drills
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
My Motorola phone Will not charge
replace battery - sounds liks the battery is bad
Sep 08, 2009 | Motorola Mobility RAZR V3
Car starts but shuts off after a few seconds.
Is that a few seconds, do you have a security light blinking?
Aug 23, 2009 | 1994 Cadillac Eldorado
My ds just crashes--shuts down--when playing. Is
The same thing happened to my DS that was 3 years old. But at a point it didn't even turn on. The top screen made a quick blink then it turned back off automatically. I suggest you just get a new DS (I got a DSi) because a new battery is VERY expensive.
Answer:It is definitely the battery, though.
Jul 07, 2009 | Nintendo DS Lite Console
I purchased Spike the Ultra dinosaur and when I turn him on I can hit the remote and he will make one move and stop and the two lights highest on his head light up for a few blinks then he is off again....
I have a similar problem. My two year old Spike only works for about 1 second after startup, then shuts down with the two pairs of lights nearest his head blinking a few times. I replaced the batteries (main and remote) with no improvement. Called tech and they said the blinking lights indicated a "motor stall" and that I should shake him to reset a position switch. I did that and now he works for 3-5 seconds then shuts off.
Dec 25, 2008 | Video Game Consoles & Games
your phone has a firmware problem.... update the firmware.. or try to reprogram
sexy-ym
Sep 05, 2008 | Cell Phones
Hp m525
ok you need to fully charge your batteris!! that always happens when batteris does not have enough charge!!!
May 15, 2008 | HP Photosmart M525 Digital Camera
Casio G''zOne Type S Cellular Phone Logo
817 people viewed this question
Top Casio Cell Phones Experts
Ekse
RONALD CARTER JR
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
