Question about Whirlpool Duet GHW9150P Front Load Washer
Washer slowly fills with water when not in use. I
Recently, my washer began slowly filling with water when not in use. I suspect that the seals on the inlet valve are failing due to hard water. But I'd like to confirm this with others who have experienced the same problem before ordering parts. My machine is 5 years old.
  • vernon_ju26 May 13, 2010
    I ordered a new inlet valve. After purchasing and reviewing the service manual, I'm 95% sure that this is the source of the problem. The only other remote possibility is that if a small amount of electrical current were being supplied to the solenoid on the valve causing it to not completely shut off when not in use. I thought that this is highly unlikely and the part was only $60 so I went for it.
I have the same problem. The only problem that I have is not knowing how much water will eventually go into the tub. It takes about 4 or 5 days to accumulate about a gallon. I called the Whirlpool service center and the woman said they recomend turning the water off after each use-I think this is ridiculous. If going away on vaca maybe. Rob
Posted on May 12, 2010
  • RobinPaul May 13, 2010
    Vernon; it is Rob again and although it may or may not be the remedy,make sure your machine is level. I moved mine around yesterday because it had travelled a few inches over the past few weeks. There is no water now,after 24 hours. worth a try.
What would cause a GE Harmony washer to fill too slowly? The water in cold water wash cycle literally just dribbles into the tub.
The filler hose has a wire mesh filter in it to keep the inlet water from passing particles that would keep the solenoid valve from closing completely. Shut off the water and take the hose off from both the faucet and the washer. clean the screen and check the one in the washer too.
Feb 15, 2018 | Kenmore Washing Machines
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Apr 16, 2009 | Dishwashers
Bosch Axxis Washer WFL2060 leaking when filling
yes.you are right.somethin might have cracked.
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Dec 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Washer won't stop filling
The mixing valve that is part of the connector where the hose is attached has either failed or is disconnected electrically.
These are simple to replace and not too expensive.
You may have gotten some debris into the valve assembly which is being held open and is a sealed device.
If this is the case, it will probably not be removable since the valve is trying to close and will only open if voltage is applied.
Aug 24, 2008 | Frigidaire CWS3600AS Top Load Washer
Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
Aug 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
118 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
