Question about Garden
How do i change the impeller in a Red lion 1.5 hp sprinkler pump. model number RLHE 150?
4 Suggested Answers
  • 154 Answers
SOURCE: 1/2 hp pump 3480 having trouble with impeller
install an inline water filte,about $40
Posted on Aug 01, 2009
heatman101
  • 43501 Answers
SOURCE: How to separate motor from
To do that you need to take the pump apart...take the bolts out that hold the motor to the pump and then unscrew the impeller from the pump shaft....
All this is not easy and will be very difficult if you are not experience and handy with your hands...
getting the impeller off in one piece can be the toughest part...
heatman101
Posted on May 10, 2011
hunter19_46m
  • 7482 Answers
SOURCE: WHERE CAN I PURCHASE THESE
Hi pierceyvicki...
You can go to the following webpage and call and talk or send an email to the Wayne distributor.
They will be able to help you get the parts you need.
http://www.midwest-pump.com/
Posted on Aug 18, 2011
Not enough flow and pressure to run sprinkler system
pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
volume flow is also important as a pump without a high output will not produce pressure
check the jet size at the foot valve that is used to help lift water to the pump
It is a jet pump and will have a smaller line back to the foot valve for that purpose
next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
you indicate 4 sprinkler heads per zone but how many zones are operating at one time
check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
check also the rpms of each pump as that also has a bearing on volume produced
Mar 26, 2017 | Flotec Pump FP4032-10MK
Rotor spins, but pump does not push water
This could be a plugged impeller. If you open the pump so you can get to the impeller you should be able to run a bent wire through the veins of the impeller. This is the first simple thing to check.
Aug 12, 2011 | Flotec 1 - 1/2 Sprinkler Pump Composite...
I have a one hp AO Smith electric pump motor for my sprinkler system which is approximately 5 years old. Well point is clean and all sprinkler heads have been replaced. I am not able to get distance from...
If you replaced your sprinklers, did you use the same size nozzles as the original heads?
I need more information and I can help you with a well/sprinkler system problem.
Gary
Jun 18, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
How to separate motor from 1/2 HP sprinkler pump?
heatman101
May 10, 2011 | Sta Rite Industries Shallow Well Jet...
I'm looking for a replacement impeller for a 1 1/2 hp centrifugal pump (for irrigation) and the only info I have for the pump a partial plate on the electric motor. This pump probably is about twenty years...
Hi, If you have removed the old impeller, the part number will be in the center. If wear has obliterated the part number, then the replacement impeller will be either spx1610-c for medium head or spx1611-c for a high head. Later models of super pumps will have a 2600 series of numbers for the upgraded drive train. However, the 1600 series drive train parts are still available.
Nov 22, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
I bought a red lion sprinkler pump with an A O Smith 1.5HP electric motor on it. A O Smith model # CET50ABH, serial # 27308J2. I knew I would have to wire it (115/230v capable) and I want to go the 115v...
Your black and white wires go on L1 and L2. It will not matter which wire goes on with line terminal as long as you just put one cord wire on L1 and one on L2. Be sure you properly switch the motor to run on 115V since it will facotry prepped for 230.<br /> <br /> John
Aug 18, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
1-1/2 hp sprinkler pump hangs up and just hums sometime
The impeller and or bearings are seized. You may have to force the impeller loose (breaking it to get the unit apart). See if you can obtain the bearings and impeller and shaft seal before attempting the overhaul. Be aware that the hardware attaching the motor to the pump housing may need lubrication before attempting to remove.
Apr 06, 2010 | Pool & Spa
My shallow well pump will not pump to 40 lbs pressure which is the shutoff setting. tHE MAXIMUM PRESSURE IS 30 lbs so the pump runs continuously. What is the problem ? Pump is Red Lion 1/2 hp series RJS,...
Installed new shallow well pump still only can get to 30 lbs pressure. when i turn pump off pressure drops to 20 lbs right away and stays there
Jun 17, 2009 | Plumbing
Irrigation sprinkler pump, flotec, 230VAC wiring
green to srcew on the motor. this is ground.,
Black on T1
Red on T2
If the rotation is going the wrong way, simply switch the black to T2
Red to T1.
Check this before you couple it to the pump..
Jun 01, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Garden Logo
848 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
